Old 08-27-2020, 06:26 PM
cnc's Avatar
cnc cnc is offline
Default Looking for all door seals and trunk seal
I also have this in the wanted section but...I’m looking for some replacement seals for my 73
Need door trunk etc.....lmk what u guys have used with good results ...thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 08-27-2020, 11:49 PM
jwcfbd's Avatar
jwcfbd jwcfbd is offline
When I replaced that seals on my 67 Firebird I got them through Classic Industries.
67 Firebird Convertible
Old 08-28-2020, 06:41 AM
cnc's Avatar
cnc cnc is offline
Hi were they OER
Old 08-28-2020, 07:35 AM
cnc's Avatar
cnc cnc is offline
Also see Metro has a kit 5 piece both doors and trunk for like $206 then on eBay same kit from another seller half the price made by metro....
Old 08-28-2020, 09:18 AM
Norwood's Avatar
Norwood Norwood is offline
I used a set of Fairchild door seals recently. Very nice product, doors closed like factory. I Highly recommend them based on my experience. https://www.jegs.com/webapp/wcs/stor...ild+Automotive
The Following User Says Thank You to Norwood For This Useful Post:
Old 08-28-2020, 11:46 AM
77 Canamman's Avatar
I will have a NOS trunk seal available in a couple of days if you want to go that route.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 08-28-2020, 12:51 PM
Norwood's Avatar
Always the best route, if you can afford it.
Old 08-28-2020, 07:05 PM
cnc's Avatar
cnc cnc is offline
77Canamman pm sent...
The Following User Says Thank You to cnc For This Useful Post:
Old 08-28-2020, 07:23 PM
cnc's Avatar
cnc cnc is offline
What about Fairchild or others for the roof rail seal that attaches into the body???
https://www.carid.com/fairchild/roof-weatherstrips.html
Old 08-28-2020, 07:34 PM
Norwood's Avatar
I only can vouch that the door seals are very good. I have good GM window seals
Old 08-28-2020, 07:44 PM
cnc's Avatar
cnc cnc is offline
Ok thanks ...
Old 08-28-2020, 07:54 PM
cnc's Avatar
cnc cnc is offline
Just ordered a set from Rockauto shipped to my door $66 Canadian.
Old 08-28-2020, 07:58 PM
cnc's Avatar
cnc cnc is offline
Now for the roof rail/window seals....
Old 08-28-2020, 08:50 PM
cnc's Avatar
cnc cnc is offline
See these on eBay
https://www.ebay.com/itm/1970-81-GM-....c100667.m2042
Old 08-29-2020, 07:50 AM
I used their belt/window seals on my 1973 Formula 455 with the large stainless trim on the belt line. They fit well.
Old 08-29-2020, 12:18 PM
cnc's Avatar
cnc cnc is offline
I actually have aset of Fairchild sweep with the chrome trim...I bought them from4004 speed I was going to remove the decor trim from the car but have now decided against it....so I will selll these and go back to the original style for replacement ...I need all 4 pieces for the doors inner and outer....
Old 08-29-2020, 12:19 PM
cnc's Avatar
cnc cnc is offline
Im also looking at Steele rubber which I have been told fit well too
https://www.steelerubber.com/cart
Parts place I assume???
Old 08-29-2020, 01:40 PM
jwcfbd's Avatar
Originally Posted by cnc View Post
Hi were they OER
yes they are
Old 08-29-2020, 11:21 PM
Formulabruce's Avatar
Based on 4 cut cross sections of Trunk seals and fit, I have found that the 1A auto trunk seal lays down in the gutter the best and seals properly. These are better fitting than what GM was selling in 1982. In Video you can see how well this conforms to the trunk channel/ gutter.
https://www.1aauto.com/1970-81-chevr...36/258266/1973
video here > https://www.youtube.com/watch?time_c...ature=emb_logo
Old 08-30-2020, 06:53 PM
cnc's Avatar
cnc cnc is offline
Bruce u r happy with them then .....good to hear.
It’s over $83 US plus any border stuff to get it here....not gonna happen.....
