Old 01-08-2022, 02:27 PM
72pontiac's Avatar
72pontiac 72pontiac is offline
Default Safe t track
Going to look at a posi unit out of 65 gto
At a reasonable price. I have 3:23 gears so I need a 3 series unit correct. He says it is. How can I be sure. A measurement from bearing to ring seat? Are these rebuildable.
As hard as they are to come by and this one being local and priced right I hate to miss out
Old 01-08-2022, 08:43 PM
Cardo's Avatar
Cardo Cardo is offline
Contact Monzaz here on the forum. I've had no dealings with him, but he has a pretty good reputation here on the forum. I plan on contacting him about rebuilding one for me here in the next year or so.
Old 01-09-2022, 02:46 AM
Geoff Geoff is offline
If you have an open diff, you can fit a PowerTrax NoSlip into your existing open centre.
Old 01-09-2022, 09:01 AM
72Pontiac, you will need a Mid Ratio Pontiac 8.2 carrier.
Will get you a measurement.
Old 01-09-2022, 09:29 AM
72pontiac's Avatar
I do see that as an option
Kinda pricey and not oem but would work
Old 01-09-2022, 09:33 AM
72pontiac's Avatar
Thanks, I see jegs has a carrier for not much more than I would have to pay for this original one but again not oem. I messaged they claim it works for an 8.2 with a 3:23 gears
But I'm skepticle
Old 01-09-2022, 01:27 PM
Usually the posi chunks have 2 rows of bolts around where the ring gear bolts on.
And peg-legs just one row.
So verify that feature
I think the thickness of the flange where the ring gear bolts on is a key factor to determine which series the carrier is.
OPH will know way more about all of this than I do.
just chiming in , fwiw
Old 01-11-2022, 12:53 PM
72pontiac's Avatar
This forums not what it used to be. Good or bad responses all sorts of people would give there 2 cents. So I committed to buy what I hope is a mid series carrier that I hope is good and I hope my 3:23 ring and pinion are good. I've made worse mistakes before so be it.
Old 01-11-2022, 01:20 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
Sorry for the delay, just got this post in digest:
I bought a new posi and installed it with used 3.23 gears in my 8.2 rear for my 65 GTO; works great, totally quiet. It was an Auburn and they now list an Eaton and a Yukon.
https://www.ronsmachiningservice.net/gm-8-2-bop-2/
Might be better than taking a chance on a used posi, in this case I just had to be sure the used gears would set up with a good pattern and they did.
Hope this helps.
Old 01-11-2022, 02:07 PM
Kenth's Avatar
Kenth Kenth is offline
Still NO Eaton or Yukon posi carrier for BoP 8.2" 3.23:1 gears.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-11-2022, 02:21 PM
tallrandyb's Avatar
Well I'll be damned. I bought the Auburn from Ron's a year ago almost exactly (January 9 2021) for the 3.23 gears:
"GM 8.2" BOP Auburn HP Posi Differential 2.93-3.23 5420114" is how they listed it, for $430. So the Auburn exists out there, not sure why the Auburn would have disappeared from their listings.
I love this setup, better than the open 3.55 it had in it.
Old 01-11-2022, 02:23 PM
Yep, too bad.
Fine print says ,,, 3.36 - 4.56
Old 01-11-2022, 02:25 PM
tallrandyb's Avatar
Yep, too bad.
Yep I missed that on the Eaton and Yukon's, that must be why my old link to the Ron's page didn't work since they removed the Auburn for 2.93-3.23 gears.
Strange!
Old 01-11-2022, 04:03 PM
AG's Avatar
AG AG is offline
Before you buy the used carrier (if it is) unbolt the two halves and check if the ends of the cones are bottoming out on the carrier. If they are, they need to be machined and the cones need to be shimmed to get the correct backlash between the pinion and side gears.
Old 01-11-2022, 04:17 PM
72pontiac's Avatar
Will it fall apart. I can get it for $225 seems like a steal. Jegs has a carrier they say will work have you seen it I bet it's a Cheby
Old 01-11-2022, 04:23 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Auburn Pro makes the only new Series 2 8.2 P 10 bolt unit for 2.93-3.08-3.23 gear, also it should be the smaller bolt size of 64-68. vs the new Eaton series 3 3.36-3.55-+++ unit. I was fortunate to find a good used series one (2.56-2.78) 69-72 unit (larger bolts LHT) for our 2.56 LeMans.. We still have good luck width good used originals but as always results may vary..
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
The Following User Says Thank You to PONTIAC LARRY For This Useful Post:
Old 01-11-2022, 04:35 PM
72pontiac's Avatar
Jegs replied it will not fit bop 8.2
Old 01-11-2022, 10:15 PM
AG's Avatar
AG AG is offline
The reason it should be checked is that if it too worn out, it can't be rebuilt and you will be out $225. If you can't rebuild it yourself you'll have to pay and then you will be approaching the cost of a new Auburn unit.
Old 01-11-2022, 10:48 PM
72pontiac's Avatar
what keeps the cones from bottoming. is it easy to check not sure if the seller can accommodate the breakdown
Old 01-12-2022, 02:52 AM
I would much rather have a cone type posi than a clutch type. Less parts to fail & I would imagine the cone type would be less touchy about the type of LSD additive needed.
