Ram Air V cam core
Does anyone have access to a Ram Air V valve layout, solid flat tappet cam core? Or I might be interested in an original NOS Ram Air V solid flat tappet cam part no. 545713? or new aftermarket cam with factory specifications.
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
Never mind it was billet roller |
Have you tried Don @DCI? With all the heads he is selling maybe he has a contact for cams.
I think Jim is leaning toward a flat tappet cam and hopefully the small dist gear on the cam like a factory?Tom
Jim, I will check through my RAV camshaft stash this weekend. I have a few solid flat tappet cams and an uncut RAV core. Jeff
Jim , check with Wade at BOP engineering also .
505 CID, 3560 lbs,Tiger heads, NA. 8.99@149.8 mph, 1.29 60', stock suspension |
i found him a NOS DS-1068 FTC,maybe that will help.Tom
Hello Jeff pm me what you want for the uncut core.
