Old 01-25-2022, 06:10 AM
PontiacLars PontiacLars is offline
Default Why the weak lifter valley
Why did Pontiac engineer the block like this? I do not see this design on Chevy, Ford or Chrysler..
i assume there was a thought behind this open design.
Old 01-25-2022, 07:20 AM
steve25 steve25 is offline
Why you ask?
Because it was all the strength that was needed to support a hydro flat tappet cam.
It may not seem like a lot , but that reduction in cast iron from what was needed to have made a enclosed
Lifter valley saved a lot of cast iron and in turn production cost on at least 70 to 100,000 blocks a year !
The open lifter valley also helps the crankcase vent better and also the oil to drain better and as it drains gets put to real good use in keeping the Cam lobes lubed.
Pontiac designers never in there wildest dreams thought that there lifter valley design of the block structure would ever be called upon to handle / accept roller lifters and 600 plus pounds of spring open pressure, nor handle Nitromethane fed thru a blower with hp levels being achieved of over 800 hp that would split the block right tru the main web’s which is a issue that having a solid lifter valley could have helped with.
Don’t knock the Pontiac block, as it was so well conceived from the start in 1955 with a cid of 287 that the engineers where able to stretch it up to 455 cid with out making any major outside design changes to the block.
No other GM passenger car motor that they ever made was able to grow 168 cid without coming out with a totally different block design!
In short I would have to say this, don’t look a gift Horse in the mouth so to speak!
The Following 3 Users Say Thank You to steve25 For This Useful Post:
Old 01-25-2022, 07:43 AM
Steve C. Steve C. is online now
Engineers Clayton B. Leach and Ed Windeler developed this cast-iron engine. One of the features described.....
"pressure-suction crankcase ventilation"
https://www.enginebuildermag.com/201...tiac-v8-power/
Old information here:
The Following 3 Users Say Thank You to Steve C. For This Useful Post:
Old 01-25-2022, 07:48 AM
sdbob sdbob is offline
I remember as a teenager working on his helping friends. It was a pain to remove old lifters from a chevy to install new cam by hand without special tools. Pontiac , I thought man this is easy to grab and work lifter free. Never thought as was said about lifter valley being open.
Old 01-25-2022, 09:33 AM
PAUL K's Avatar
PAUL K PAUL K is offline
You are correct. Lisle used to make a lifter puller tool. I remember seeing it at the auto parts store and thinking it was a scam. Then I helped a friend replace his lifters on his SBC and realized why one might need that tool.
Go fast, see Elvis!
Old 01-25-2022, 09:39 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Buick and Olds blocks are open like that too.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 01-25-2022, 04:25 PM
Half-Inch Stud's Avatar
I recall that only 2 Lifter bores are weakened: Both on the Even Bore side.
All Odd Bores are plenty tuff.
Old 01-25-2022, 05:11 PM
Douglas Willinger's Avatar
Douglas Willinger Douglas Willinger is offline
Default Per unit cost?
How much money was saved by such a design per unit.
Suppose they had instead used the RAV/SD455 design? How much cosltier per block?
Why you ask?
1970 Lucerne Blue Firebird Trans Am, deluxe blue interior. Original Ram Air III, M-21, 3.73. Being built as a 4" stroke "434" with SR 614 Ram Air IV heads
1972+ Lucerne Blue 4-door hardtop "what if" T-41 Le Mans Sport GT/Grand Am concepts. Equipped with future 3" journal "455 HO"/"what if" prototype "SD 455".
What if GM had continued production of the 1970-72 GM A body somewhere in the southern hemisphere?
Old 01-25-2022, 08:02 PM
Tom Vaught's Avatar
Boost Engineer
There was a speed shop in the Dearborn Michigan community called Mayfair Auto Parts.
Joey Fair, I believe was the owner. He was a dirt track racer and liked Pontiac engines.
(I have posted about the following subject in the past).
Joey liked stroker engines and ran 4.5" stroke cranks when the 421 Pontiac crank was a 4" crankshaft. Whitey at Moldex Crankshaft would make the forged cranks for Joey.
One of the mods Joey would make was to add 3 cross bars between the heads to help
support the upper end of the block when using the stroker cranks.
I posted this info years ago for Dick Duclow and Tom, as well as Bob & Frank.
And Dick and Tom and Bob and Frank had the first Indian Adventures blocks cast up with a Sealed Lifter Area as well as all of the All Pontiac Blocks.
Rodney Butler ran one of the Indian Adventure blocks for years.
So there WAS A REASON why the aftermarker blocks were cast up with a closed lifter valley.
Thanks Joey Fair, Dick/Tom, and Bob/Frank for that design.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 01-25-2022, 11:54 PM
slowbird's Avatar
slowbird slowbird is online now
Yes 2 weak bores found here.
The Following 2 Users Say Thank You to slowbird For This Useful Post:
Old 01-26-2022, 12:22 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
Is that a solid roller with no bore bracing?
Old 01-26-2022, 01:19 AM
slowbird's Avatar
No, HR
Old 01-26-2022, 01:57 AM
Dragncar Dragncar is offline
I asked Jim Butler that very question. He said " to save 50 cents a block".
Old 01-26-2022, 02:00 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Slowbird, sad to see that. Is that from rpm, too much spring tension etc?
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
Old 01-26-2022, 03:49 AM
Which engine was this ? Sucks.
Its my nightmare to tell you the truth.
Old 01-26-2022, 07:55 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The only Pontiac engine we ever lost here took out a lifter bore and it had a brace in it. It was using a pretty hefty solid roller cam, lots of spring pressure and drag race only. It lasted 13 runs after the rebuild. The engine let-go in the lights at 6400rpm's and about all we saved from it was the oil pump and a few of the Crower connecting rods!......
The Following 2 Users Say Thank You to Cliff R For This Useful Post:
Old 01-26-2022, 09:10 AM
Mike Davis's Avatar
3 years ago when I broke a valve in my 421 in Fla, I had a 400 stroker build I bought from a friend to use as a spare, I threw it in the car for the Atlanta race while the 421 was getting sleeved. Thought for 1 race I would not put a brace in it since the engine was already assembled. 270@.050 solid roller.
It let go at the finish line in lights at 6700 and nothing was salvageable. Wild ride at 134MPH.
ID:	582728   Click image for larger version
ID:	582729   Click image for larger version
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 01-26-2022, 09:24 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Yup, and no discussion of them breaking. Then lightening up the main webs from 1977+ by leaving big holes in them, ugh. But I put 280,000 on a 1977 olds 350, so they do last with barely adequate maintenance and decent amounts of abuse.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 01-26-2022, 09:47 AM
Cliff R's Avatar
"Aggressive" roller lobe profiles and strong springs are a recipe for disaster with a Pontiac block. Even with a brace in it you can still loose one as we did.
Haven't had any issues to date with "softer" roller cam profiles and lesser spring loads, so really nothing to worry about unless you are building a pretty high end or max-effort street/strip or full race engine, and even then with a brace in them we aren't hearing about a lot of folks busting out lifter bores......
The Following User Says Thank You to Cliff R For This Useful Post:
Old 01-26-2022, 10:23 AM
scott70's Avatar
scott70 scott70 is offline
so I assume its the side loading of the lifter that breaks the bore?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Thread Tools
Display Modes
