Old 01-03-2010, 12:52 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Originally Posted by shaker455 View Post
We'll have to talk "carb" for you sometime.
Jeff, I'm with you on that.Once I get the right combo together ,I'll be giving you a call.
Old 01-03-2010, 01:33 PM
Originally Posted by Skip Fix View Post
So has anyone measured the plenum depth compared to a Victor?
The plenum depth on the North Wind is 3.75",same as a T2.I'm going to try and send some photos.
Old 01-03-2010, 01:56 PM
More Photos,you can see some of the port work that Kauffman's did.
ID:	192680   Click image for larger version
ID:	192682   Click image for larger version
ID:	192683   Click image for larger version
ID:	192684   Click image for larger version
Old 01-03-2010, 02:57 PM
PONTIAC DUDE's Avatar
Wink
Looks similiar to the ole Warrior intake at the top.
Old 01-03-2010, 03:14 PM
Ken,Do you know the plenum depth of the Warrior intake?
Old 01-03-2010, 07:49 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Victor is 3.920 front and back. My T2 3.650 front 3.780 rear of plenum
Skip Fix
Old 01-03-2010, 09:20 PM
Skip, thanks for the info.
Old 01-03-2010, 09:31 PM
Skip Fix's Avatar
Since the Victor looks like it has at least a 1/2" "spacer" cast into it they must have dropped the plenum floor on the Northwind to keep that much plenum depth. Otherwise sure looks like a milled down Victor to me.
I can give you plenum depth on a M/T cross ram too if you want it
Skip Fix
Old 01-03-2010, 09:36 PM
Here's a few comparison pictures -North Wind / T2
ID:	192740   Click image for larger version
ID:	192742   Click image for larger version
ID:	192743   Click image for larger version
Old 01-03-2010, 10:11 PM
shaker455's Avatar
shaker455 shaker455 is offline
I would say it's the Victor jr for Pontiacs but not from our friends at Edelbrock.
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 01-04-2010, 02:18 PM
gearbanger's Avatar
gearbanger gearbanger is offline
I heard there isn't enough meat without welding to install it on tall 2.3"+ ports. is that right?
Old 01-04-2010, 07:45 PM
67 Lamnas's Avatar
67 Lamnas 67 Lamnas is offline
Originally Posted by ponjohn View Post
I believe it is shorter by about .650.
Originally Posted by Hammertime Mike View Post
OLDFLM72 and Exil here are some measurements taken with a T2 and a standard $270 North Wind.The North Wind measures 3/4 inch taller than the T2.The T2 appears to be unmolested ,these are the port measurements-1.040 wide and 2.0625 high giving a cross sectional square inch of 2.145.The North Wind port measurements-1.1875 wide and 2.1875 high giving a cross section square inch of 2.598. PLEASE NOTE that these are my measurements and not official data. I never measured my ported North Wind before I installed it.I will have more photos posted(HOPEFULLY at a size that is useful).
Well...I'm not completely done measuring since I nearly froze my fingers off in the garage (it's 4 below zero here right now) but the Northwind is 1-1/8" taller in the front than a Torker 2......
Only reason I bring this up is because I don't have a lot of extra room for hood clearance and I just pulled off my Torker 2 and 1/2" spacer and was hoping they were close.......now I hafta figure out if I can fit another 3/8" or how much shorter an air filter I can run without choking off the carb....where is WFO Larry when I need him??..haha
Hammertime, with your height measurement, did you measure side-by-side with the manifolds on the bench or on the engine?
Ponjohn, you're about right if you meant the Torker 2 is .650 shorter
One other thing to consider for those with hood clearance issues is the slope of the carb pad....there isn't any with the Northwind (or the Victor, for that matter) like there is with the factory and other aftermarket manifolds....part of the reason I measured from the front......
Old 01-04-2010, 07:54 PM
shaker455's Avatar
Hey Jim,
You running a GTO hood?
Not sure if I ever saw pics of your car??
Old 01-04-2010, 08:09 PM
67 Lamnas's Avatar
Hey Jim,
Nope....standard Lemans hood.....just another one of the many compromises I make to pass off my 535 Lemans as factory-stock....hahaha
Old 01-04-2010, 08:28 PM
shaker455's Avatar
Well if you sprung out of the box a bit and got a GTO hood we might be able to grab you a bit more air for your big breather!!!...LOL
Old 01-04-2010, 08:32 PM
shaker455's Avatar
Mike,
We'll get you fighting with Chris!!
I'd like to sell tickets to that dance!
Old 01-04-2010, 10:16 PM
rad400 rad400 is offline
The Nothwind looks like a nice intake.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
  #38
Old 01-04-2010, 11:11 PM
67 Lamnas's Avatar
I'm cheap.....
  #39
Old 01-05-2010, 11:18 PM
shaker455's Avatar
Originally Posted by 67 Lamnas View Post
I'm cheap.....
Yeah Right Mr.535.....
  #40
Old 01-08-2010, 09:30 PM
I had to take additional pictures and measurements to more accurately document my findings of the comparison of the North Wind and Torque II intake manifolds. Things to keep in mind - these are my measurements (not the official documentation from edelbrock and Kauffman Racing Equipment).Hopefully this will clear up any confusion.
The T2 has an angled flange. I believe this is to keep the carborator level (engine sits at an angle.. lower in the rear). The angle of the T2 Flange, is in reference to a varified level surface, is approximately 4 degrees.
The North Wind flange is level.
The T2 plenum depth is deeper in the rear and shallower in the front due to the angled flange. (doesn't seem to be optimum).
The T2 plenum depth is approximately 3.858 deep in the rear and 3.660 deep in the front (difference in depth is a result of the angled flange)
The NW plenum depth basically uniform at 3.735
Note: plenums of both manifolds are "as cast" and can vary +/- a few thoudands of an inch.
Note: One thing to understand is that the NW flange is centered on the ports making it balanced. The T2 the flange is off set to the rear making the runner appear shorter compared to it's front runners. The offset to the rear is approximately 1.0625 off center.
ID:	193260   Click image for larger version
ID:	193261   Click image for larger version
ID:	193262   Click image for larger version
ID:	193263   Click image for larger version
