Old 12-17-2019, 05:48 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Default Motor plate question
I have a car with a 1/4" front motor plate and a CSR water pump. The motor plate is between the timing cover and the water pump.
I'm about to swap in an engine that had a 1/4" motor plate between the block and the timing cover. And I'm going to use a Meziere water pump.
Is one way better than the other? Do both mounting styles use the same timing cover? And will I need spacers when using the Meziere water pump?
Thanks.
www.lancablingsolutions.com
Old 12-17-2019, 05:54 PM
GTOGEORGE's Avatar
Mine is between the block and timing cover, I like that better then the other!
GTO George
Old 12-17-2019, 09:48 PM
Mean Green's Avatar
GTO George
I agree. Looks like it would be easier to mount a vacuum pump, alternator and crank trigger with the motor plate between the block and timing cover.
Old 12-18-2019, 01:27 PM
Mean Green's Avatar
Anyone have pics of a vacuum pump setup on a front plate between the timing cover and the water pump?
Or do I remove a large section of motor plate and mount the vacuum pump to the head?
Old 12-18-2019, 02:13 PM
mysticmissle's Avatar
i have two cars one with the plate behind the timing cover the other with the plate infront. Both of my vacuum pumps are set up off the passenger side head. Both work fine.
I think the plate behind the pump is a little cleaner, but it also makes it a little harder to get the motor out with the front plate still on. Also if something ''happened'' to the milled timing cover i would have to get another machined. I have 6 stock timing covers ready to go for the other one.
pick one you like the best and fits your chassis best, don't over think it.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 12-18-2019, 02:23 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
I like the plate mounted to the block.
Name:	vac. pump (1).jpg
Dave Polichena
Old 12-20-2019, 05:16 PM
Mean Green's Avatar
Thanks for the help and the pic.
I decided to switch to an All Pontiac motor plate. My other car has one, and that way I can easily swap engines between cars if I want to.
Old 12-20-2019, 06:08 PM
Mean Green's Avatar
Old 12-25-2019, 09:15 AM
chuckies76ta's Avatar
So when does one have to start thinking about a motor plate? I'm building a 505 which should do about 750 hp. Going in a 68 Firebird. I already have mighty mounts with a tie down plate off driver side head to frame. It's a full plate mounted across head. Turn buckle style tie down. The plate is 3/16 steel mounted under accessories. I was thinking front only motor plate with the same motor mounts.
Need opinions please.
Charles
Old 12-25-2019, 07:56 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
So when switching to a motor plate between the timing cover and the block, how do you address the timing cover to the oil pan lip?
Old 12-25-2019, 08:34 PM
The timing cover is machined for clearance the thickness of the motor plate. Everything lines up that way
1964 540 gto
Old 12-25-2019, 08:45 PM
Isn’t it better to install on front of the timing cover?
Charles
Old 12-25-2019, 08:46 PM
So gasket on each side of plate?
Charles
Old 12-25-2019, 08:49 PM
Ok. So engine plate on front,Solid motor mounts. That ok?
No mid plate. ?
Charles
Old 12-26-2019, 02:20 PM
Yes, gaskets on both sides.
No more need for engine mounts, I have a travel limiter bolted to engine mount bolt hole that goes to frame and use rubber mount on the trans.
Dave Polichena
Old 12-28-2019, 03:30 PM
younggto younggto is offline
With a front plate I believe you want either a midplate (with a travel limiter) or retain the stock mounts. Not saying it won’t work but there was a thread recently on YB and that was the consensus.
Old 12-28-2019, 04:05 PM
73 TRANSAM 73 TRANSAM is offline
If you have to pick which one will take the stress off the block, then mid plate will do that. Ideally mid plate, front plate and travel limiter is the best set up.
Old 03-31-2021, 01:17 PM
Mean Green's Avatar
Before pic: With the aluminum plate in front of the water pump.
After pic: With the All Pontiac plate. I like the cleaner look of the AP plate. I took the AP plate to a local metal shop and had it bent to fit the same mounts the aluminum plate used.
ID:	563762   Click image for larger version
Old 03-31-2021, 05:51 PM
misterp266's Avatar
Had to turn them . .
ID:	563806   Click image for larger version
" Darksiders Rule "
Old 03-31-2021, 06:17 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
I've always read this about a travel limiter, but, FWIW, I run just the mid and front plates, no limiter and I've had no issues. Incidentally, I believe with front and mid-plate, you should run a poly rear trans mount---not solid.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
