Valve spring tester question.
Hello all, I’m thinking of buying an on the head spring tester like the Moroso ones.
I guess I’m not really understanding how to use one or how it works. Most of them list a max pressure that isn’t that high, 300 lbs on some. That is less than the open pressure on a lot of springs. Does it just show the spring tester and then you have to figure your open up? I’m feeling very dense right now. Thanks Murf |
Just be aware these types of testers can vary considerably compared to a calibrated bench tester like a Rimac machine. Springs can lose pressure after run in and over time. Therefore we use the on the head spring tester only to monitor the springs with use.
https://www.youtube.com/watch?v=6LpX_hC_ijM As noted in the above, test each spring a few times. And make sure it's positioned correctly. https://www.moroso.com/pub/media/ins...62388_inst.pdf .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-21-2021 at 06:46 PM. |
The Following User Says Thank You to Steve C. For This Useful Post: | ||
LSM make some very nice tools for working with valve springs. There expensive but worth ever penny in my opinion. I purchased the on head valve spring tester, and the tool for removing the valve springs.
https://lsmproducts.com/products/sc-800-for-stud-mount https://lsmproducts.com/collections/...ressure-tester
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
X2 .
