Old 08-27-2023, 06:09 PM
Rar_421 Rar_421 is offline
I have a spot check dye penetrate kit,are those reasonably reliable?
Old 08-27-2023, 06:10 PM
steve25 steve25 is offline
Even if you only have a small Dremel tool with a stone polish up that area as it can help make
Cracks show up better.
Old 08-27-2023, 06:12 PM
Sirrotica's Avatar
If there is a crack, and it's hard to see, all you need to do is heat it with a propane torch. As the metal expands the crack will usually widen, allowing you to see it more easily.
From your picture, I can't see anything obvious, but it doesn't mean it's not there. Try some heat to see if it shows up better.
I'd also ask what method they used to determine there was a crack to begin with. The reason there are test procedures is to find cracks not easily seen with the naked eye. You might also want to get a magnifying glass and study the area more closely too.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 2 Users Say Thank You to Sirrotica For This Useful Post:
Old 08-27-2023, 06:16 PM
Sirrotica's Avatar
I have witnessed someone using a dye detection kit, it showed up the crack when the red bleeds back through the white. Only time I've seen one used was that time, but there was no doubt where it was after the test. This wasn't in an automotive setting, but in a tool and die shop.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-27-2023, 06:17 PM
Looked it over with a magnifying glass,2x power,didn't see anything,on the phone he said no fixing this block,I assumed it was cracked up in the lifter area,I'll have to dig out my Dremel and clean it up and try a little heat as you suggested
Old 08-27-2023, 06:25 PM
LM93 LM93 is offline
Dye penetrant tests can find defects too fine for Mag tests, but they need a smooth surface to not hold dye. Sanding stone will work great.
1979 Esprit, Starting the Resto-Mod Process with a 350 and a TKO 600.
"And the one thing you can say about Capitalism is that, although it produces inequality-which it absolutely does-it also produces wealth, and all the other systems DON’T. They just produce inequality." Dr. Jordan Peterson
The Following User Says Thank You to LM93 For This Useful Post:
Old 08-27-2023, 06:58 PM
The last set of Buick heads I was porting a thought for sure I had found a crack so I stopped.
The owner then took the head to get Mag tested and it showed zip.
Old 08-27-2023, 10:49 PM
Formulas Formulas is offline
to bad you cant put air pressure in this block and spray soapy water look for bubbles
Old 08-27-2023, 10:58 PM
At this point I have to take his word until I can polish it out and try a little heat and the dye penetrate kit, if nothing shows I'd still rather have a a second opinion from another shop but there all 2 to 4 hrs away
The Following User Says Thank You to Rar_421 For This Useful Post:
