'64 GTO Radiator Oil Cooler Fitting
Can anyone tell me what size the fitting is on a '64 GTO?
3/8......... 5/16......??
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine" 1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS |
3/8"
Thanks again Bart.
My friend went out and removed the old radiator and he says it is 1/4" NPT.
Alan will call him today.
If he wants 1/4" NPT - that's what he'll get.............not a problem.
Just wanted to let you know. I will now get out of the middle - again - hopefully this time for good.
The radiator will ultimately need to have 3/8" inverted flare fittings to mate up with the cooling lines.
You can of course use a 3/8" inverted flare male connector that has 1/4 NPT threads on the other end to mate up with the trans cooler built into the radiator that has 1/4 NPT female threads. |
