Old 05-20-2022, 09:27 PM
R 70 Judge's Avatar
Default Help identifying gauges
I’m a bit confused with my gauge cluster in my 1970 Trans Am and I’m hoping some of the experts can help me identify what I have/what I need. My goal is to have the correct appearing gauges, engine turned dash, and chrome bezels for 1970.
Please correct me if I’m wrong, but I think I have the correct tachometer, wrong speedometer (obviously not 160), correct oil/water gauge, and correct voltage gauge. I’m missing the fuel gauge. I’m guessing the engine turned dash is 74-76?
Just to add my car is non-A/C. Are the heater controls original?
Any input is appreciated
ID:	591210   Click image for larger version
ID:	591211   Click image for larger version
ID:	591212   Click image for larger version
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 05-20-2022, 09:41 PM
R 70 Judge's Avatar
Few more
ID:	591219   Click image for larger version
ID:	591220   Click image for larger version
James
1970 Trans Am
Old 05-21-2022, 02:22 AM
FASTASSBIRD FASTASSBIRD is offline
Bezel is for sure wrong as it has radial tuned suspension badge. Speedo for sure is wrong l, should be 160 AND only have a brake light. Heater control unit looks correct. 70/71 use de-ice, not defrost like 72 and up
The Following User Says Thank You to FASTASSBIRD For This Useful Post:
Old 05-21-2022, 01:02 PM
Peter Serio's Avatar
Default 1970 Trans Am, original GM gauges
The speedometer and fuel gauge you need look like these 2:
Name:	70 Trans Am fuel gauge.jpg
ID:	591259   Click image for larger version
Name:	70 Trans Am Speedometer 160 MPH.jpg
Peter Serio
Owner, Precision Pontiac
The Following 2 Users Say Thank You to Peter Serio For This Useful Post:
Old 05-21-2022, 06:27 PM
Ramairnacho Ramairnacho is offline
Default 1970 speedo cluster
The 1970 rpm guage is 1 wire only they used 2 wire I believe up to 74. I have 2 or 3 of each. The 250 psi max oil guage was used up to 1973 so that's correct. The 1970 had a black flower knob but if you have a 2 wire yack knob thread different as I learned from another thread. The speedo is to be a 160 mph with seat belt warning at bottom. The fuel has orange under 1/4 tank marks and is 1 year only too. This is my hobby but I like guages alot so always learning. I believe there is a post where someone installed dogital.guages that look the same. I believe mechanics is digital. I'm working but when I get home I'll send you pics of my collection and a 1970 bezel isn't cheap. I seen one at a friend's garage in Sacramento CA about 9 months ago. I have a 1970 formula 400 ra3 and it had warning lights only not goodso im.upgrading along with tilt steering.
Old 05-21-2022, 07:33 PM
Formulabruce's Avatar
The second warning light under the speedo did not Start to appear until Dec of 1971 for the new Calendar year DOT laws. Any 1970 bird does NOT have the seatbelt warning.
Just trying to keep history correct..
The Following 3 Users Say Thank You to Formulabruce For This Useful Post:
Old 05-22-2022, 11:38 AM
Default Guages
I tried sending pics last night it didn't let me I'll try again today
Old 05-22-2022, 12:16 PM
FrankieT/A's Avatar
Agree!
And I believe the two wire tach started in '72. The '72 has an entirely different wire harness compared to '70-'71.
The Following User Says Thank You to FrankieT/A For This Useful Post:
Old 05-22-2022, 04:15 PM
Default Guages
I'm at work and have a baby I will try My best to help you. I bought 2 correct ralley sets one I had to drive 3 hours for the fuel guage. I'm not bragging for one. But also built as a boy a rally set from parts I found at local wrecking yard not easy either. I have I believe 1 or 8 later 8 grand tacks. I'm not sure if you running stock points still not sure if anyone is but if you are the stock tac will work but not sure if it works on patronix or hei. Another thing is if you still have stock transmission and its accurate with later speedo then that needs to be recalibrate. Yeah I been dormant for 25 years built 5 dIly driver formulas with used parts not date coded and its a lot less stress than this high $ correct stuff. But now adays you can not find a $250 roller any more. I'll try again tonight
Old 05-22-2022, 06:07 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
Can confirm my 70 does not have the seat belt warning light.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-23-2022, 12:53 AM
Default Rally 1970 guages
Ok this is correct factory guages. The tqc is a 1 wire that I believe only works on points not on hei or payroll but I might be wrong I need to find out. The fuel is a 1 year only with orange under 1/4 tank. Honestly if you have a 2 wire put the hei and it should be fine, . Like said before speedo had brake only. Temp only 250
ID:	591368   Click image for larger version
The Following User Says Thank You to Ramairnacho For This Useful Post:
Old 05-23-2022, 07:07 AM
necdb3's Avatar
necdb3 necdb3 is offline
Nice find and it even has the original clock knob!
Old 05-23-2022, 08:51 AM
Thanks .sending I'm future to recdine gusgrs to get cleaned and overhauled plus calibrated
Old 05-23-2022, 09:05 AM
FrankieT/A's Avatar
My gages are 1970 one wire deal and I have used HEI with it for years-works perfect and pretty accurate compared to FI hand held.
Old 05-23-2022, 10:58 AM
Thanks wasn't sure if it did. My original plan was hei but now decided to run a patronix system hope it works for that as well.
Old 05-23-2022, 02:36 PM
jhein's Avatar
jhein jhein is offline
I converted my dist to a DUI HEI before I found this: https://progressionignition.com/
I bought the HEI version which I'll be using on the new motor. Looks pretty slick. If it works as described and is reliable should be great.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 05-23-2022, 04:29 PM
FrankieT/A's Avatar
WOW !!! very cool. Reliability ??
Old 05-23-2022, 04:35 PM
jhein's Avatar
I can't comment on reliability yet since I don't even have it in the car running. But, other members here are running them. Do a search on it. Also a general internet search will reveal lots of other people running them with seemingly good feedback.
I just think the ability to customize your timing curve like that is fantastic.
Old 05-23-2022, 05:22 PM
FrankieT/A's Avatar
Fantastic ??? I think maybe the best thing since sliced bread ! Lol
Old 05-23-2022, 05:27 PM
jhein's Avatar
I do have a tendency towards understatement...
