Old 05-02-2009, 07:53 AM
engineer9's Avatar
engineer9 engineer9 is offline
Default 61 - 62 Timing Chain Cover
WANTED ASAP: 61 or 62 Pontiac 389 Timing Chain Cover (GM 538144 or 538144 for 1961) or (GM 541504 for 1962) in good condition, particularly internal seal boss. Hub bore for crank is 1.925" / 1.935" straight thru; seal boss is 2.395" / 2.450" OD. 1963 GM 548689 / 548690 may also be interchangeable with 61 / 62...anyone know?
Old 05-02-2009, 10:16 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
I should be able to help you out. I have a 62 Bonneville parts car that still has the engine in it. PM or email me if you still need one.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 05-20-2009, 11:39 PM
engineer9's Avatar
Default 1962 Timing Chain Cover
Thanks for checking, Jeff! I found one locally...great shape, newer type seal, $45!
