455 engine Freeze plugs on cylinder heads
Hello, a newbie to this forum but I have 3 GTOs (66/389, 70/400, and 70/455).
I own a 70 GTO 455 Convertible auto 4BBl with the PHS documentation that is one of 241. I have rebuilt the whole engine and the cylinder heads have freeze plugs that I like to replace (I did the engine freeze plugs). I researched this forum and there are two sizes quoted in the same thread, one for a 1 3/16" size and one for 1 13/64", same post. There is no resolution discussed as to why the two numbers. Are the differences so small it does not matter? I do not want any hassle, or having to disassemble the heads again if I use one that leaks at a later time. Hence this post. Any help would be appreciated. AS stated above, when I ran my first search in Google ("GTO 455 Cylinder head freeze plugs") I wind up in this forum (here): https://forums.maxperformanceinc.com...d.php?t=850624 The first size quoted in that thread is made by Dorman for which a box of 10 has to be purchased, the 1 3/16" is sold individually in Ebay. I am not looking for cheap parts, I need the correct sized one (even if I have to buy a box of 10). Thanks. Guillermo Last edited by gquincoces; 06-07-2022 at 12:29 PM. Reason: to make it clear |
The Dorrman part number for what you need is 555-020.
It's a 1 1/8" .470"deep.
I do stuff for reasons. |
Sorry my above post is 100% wrong !
I do stuff for reasons. Last edited by 25stevem; 06-07-2022 at 02:46 PM. |
455 cylinder heads
that was quick and certainly worth the wait, Still a different size, but the writer took the trouble. So, thank you so very much. Guillermo
Here is what I show for the freeze plugs:
Pioneer EPC-80(B) The EPC-80 is 1 3/8". (goes on front and back of head) and EPC-134(B). it is 1 13/64". This goes where the intake bolts on (intake face side.) (the 'B' is for brass plug)
The Following User Says Thank You to johnta1 For This Useful Post: | ||
455 cylinder heads
Thanks for the information, I purchased the wrong ones, but I will try to cancel th order and get the right ones. Guillermo
Here’s the info right off a set of my heads just to help you rest assured that indeed what John kindly posted for you is correct, unlike what I had in my first post trying to go by memory.
Each end of the head takes a Doorman 555-025 ( 1 3/8”. ) so you need 4 of those, and then on the intake flange they are 1 13/64”. Mine are perfect circle brand PC 134.
I do stuff for reasons. Last edited by 25stevem; 06-07-2022 at 04:57 PM. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
Ok 4 for the 1 3/8 and how many for the 1 13/64??
You will only need one of the 1 13/64".
This is for the opening at the back of the head behind the intake.
The other side will have the heater hose nipple in it. |
You need 3 of the second type if your still running the nipple to hook up the heater.
Only one if you’re using the heater hose nipple on the passenger side head. Two if you’re not running the heater and plugging the hole where the heater hose nipple would normally reside. The intake manifold front coolant crossover covers two of the holes so certainly no plugs needed there.
The Following 4 Users Say Thank You to b-man For This Useful Post: | ||
Thanks for the correction!
I’ve needed a spare at times though.
