Old 11-13-2021, 05:50 PM
punkin punkin is offline
Default Replacing Rear - Additional Items?
Hello all,
My new Ford 9" rear and Caltracs have finally arrived. I should have looked into this some time ago but, it now occurs to me to ask if while I'm at it, should I replace the U-bolts and the rear shackle hardware? Are these considered wear items or should these be upgraded as I am applying a lot more power and torque than factory?
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 11-13-2021, 07:59 PM
JLMounce JLMounce is offline
Yea I would replace them. I would also consider replacing the front spring eye receivers as well. Because the bolt into the frame and laminate, they are prone to trapping moisture and dirt, causing rot.
Inspect your upper shock mount retaining plates as well. Replace if necessary.
-Jason
1969 Pontiac Firebird
Old 11-14-2021, 11:30 AM
I thank you for the recommendations. I was considering installing these when I get the subframe connectors welded in. I'm just blown away by the cost but I haven't found anything comparable.
https://www.detroitspeed.com/detroit...irebird-040110
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 11-14-2021, 12:48 PM
With the power you’re making those would probably be a good idea.
-Jason
Old 11-14-2021, 01:00 PM
Jason, as always, I thank you for the great advice.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 11-15-2021, 04:35 PM
Hello again,
Anyone aware of other ways to reinforce the front spring pocket? I contacted Detroit Speed this morning and they're indicating that their heavy duty spring pocket kit won't work with Caltracs. I've been doing some www searching but haven't found anything as yet.
Thank you.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 11-16-2021, 06:44 PM
Tom Vaught's Avatar
Boost Engineer
I would call Calvert and see if he has something similar in function that would work with
his Caltracks.
Tom V.
