EFI Tech All things EFI and making classics modern!
Old 04-23-2018, 07:41 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Default EFI fan control
Those of you using a Holley Sniper/FiTEch EFI with electric fans. Are you using the efi's fan control or a separate controller ??
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 04-23-2018, 09:28 AM
Scott65's Avatar
Scott65 Scott65 is offline
I have FAST, not those mentioned, but I let the ecu control the fans. It's reliable, though not as adjustable maybe as a laptop tunable ecu. Looking forward to my megasquirt install, as I think I'll be able to add more parameters than just temperature. Would be nice to use tps to have it automatically shut the fans off at freeway speeds.
