Warrior intake.
I have a old 4150 style warrior intake. Can anyone tell me anything about these intakes. I have talked with two people that have used them in the past. One guy really liked , one guy hated it. So is it worth keeping and using? Or am I better off spending the money and getting a newer intake?
Years ago with lower flowing heads and a limited aftermarket they worked very well. Today it's maybe not as good of a option as others out there. Torker 2 / performer rpm and Victor filled a gap we had years ago. I personally like the old school stuff.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Well I will tell you this. It is the coolest looking intake for a Pontiac I have seen.
The Doug Nash pieces were cast up for the Herb Adams/Tom Nell racing Pontiac Engine Programs. Pontiac was out of racing but some employees still developed the parts for other racers. Doug Nash started out as a Skilled Trades Plumber at Ford in Dearborn Michigan but was a hard core racer of any brand therefore he was happy to work on the project with the Pontiac Racers. He told me he had a Ford Model Maker make the runner shapes based on the design from another individual. Doug had the intakes cast up initially for only the Pontiac guys and specifically for a 366 cid engine size.
This is why some guys have good luck with the intake on a 400 cid engine and the 455+ engine guys are not happy with it. A SMALL PLENUM VOLUME. But the racers figured out how to add plenum volume to the intake on the bigger engines and make it work well. The Victor intakes would better out of the box vs the Doug Nash stuff on the larger engines. So what do you want to do with your engine program? Engine size, etc? Advice is not "Good Advice" without specific information. Tom V. Tom V.
I figured the plenum was on the small side. I thought it would really work better with spacers. |
I think in one of Pete McCarthy's early books he goes over dropping the plenum floor on those intakes to increase plenum for a 455.
Seems spacers would work also. The Holley Street Dominator (Tomahawk) also has a small plenum but lots of guys have used them om 455s with success. Dave Bisshop even modified them for Dominators. Friend had one a a 461 that made 642 HP and runs 10.50s in a 63 Tempest.
I dropped the floor on mine years ago. Approx, 1" more plenum plus spacer on top. I ran some 9.40's with RA4 Heads and 455 short block. Car was 3140lbs back then.
So how do you drop the floor?
You cut the bottom of the intake plenum away. Then you add a spacer ring milled from 1" solid plate that matches the lower part of the plenum, and then if you are lucky when you removed the floor of the plenum you can trace a pattern of the spacer ring and weld a piece of aluminum on to it to seal it up. You can add the floor plate first and remachine the spacer ring top so that it is a perfect match for the intake, tack it in place, and then later slowly fill in the openings between the spacer ring and the original intake. Either leave the welds as finished or smooth them out a bit.
That is the "PRO" way you can cobble on a basic box extension a bunch of ways. Tom V.
I used a Nash intake back in the mid 70's on a 461 and RA4 heads. It worked well but really liked the 2" carb spacer.
Yeah I was thinking it needed a 2" spacer
Tom is spot on. You cut the floor and plate it. Costly to do however. Adding spacer on top is fine, however it does not Improve the floor to roof height going into the runner. You can grind a certain amount out of the roof and floor, however It will still be relatively small.
You can do that,however you would need to add weld on the runners transitioning into the top of the plenum. You need to have a nice transition into the port via the roof area.I am currently doing a Nash Intake. We added weld to the runners on the top and underneath to achieve more plenum. Hope this helps.
[QUOTE=potentpontiac;5676175]You can do that,however you would need to add weld on the runners transitioning into the top of the plenum. You need to have a nice transition into the port via the roof area.I am currently doing a Nash Intake. We added weld to the runners on the top and underneath to achieve more plenum. Hope this helps.[/QUOTE
Well it does. I am going to try it the way it is right now and use spacers. When I have the time and money I may try doing these mods . This may sound silly. But the intake looks really cool and I kinda want to see it on the car. Sometimes vanity takes over ! |
If you had no hood clearance issues or it was a drag scoop deal then you could simply add BOLT-ON the 2" spacer, and you pick up what volume that spacer gives you. Maybe it works maybe it doesn't. Where the roof of the runner is makes a difference.
If you thought about adding a large box above the normal plenum, you can forget that deal as you just added a ton of plenum volume and killed the signal from the intake runner to the car booster. Look at a tunnel ram. Big plenum but the top of the runner is typically with-in a inch or two from the carb base. You are not sharing between a couple of carbs, you are just killing signal to the one carb. The dropped floor adds an inch of volume to the plenum with no real issues. The 1" spacer adds an inch to the upper volume. If you add all of the volume on top of the intake it is a crap shoot if the carb works good. Have a great (pre New Year's) Evening. Tom V.
Yeah I didn't think about that Tom. Most intakes will raise the entry to the port up when they move the carb up higher .
I want to think I saw one on JB Clegg's SD455 Super Stock car at one time.
Phew, still glad i traded my nice Nash manifold for a 69 TA hood, yet that was so long ago.
Would be so tempted to hog and cut if had the Nash manifold now. |
