Old 08-23-2019, 01:30 PM
tallyhoe's Avatar
tallyhoe tallyhoe is offline
Default New muncie 3spd drive gear
Looking for a new plastic gear that goes on the cable on the trans side for my 71 gto with a 3spd manual. Any ideas where i could get one?
Guy
Lucerne 71 gto
Old 08-23-2019, 02:05 PM
unruhjonny's Avatar
I believe I know what you're talking about;
If I understand you, this is not muncie three speed specific, but rather specific to the gear set you have, and works with the gear pressed onto the main shaft.
Do you have your old gear?
They are selected by the gear in your transmission, and the gear set you have out back;
I believe that the 'drive gear' is the one on the transmission main shaft, and that the 'driven gear' is the one that sits in the end of the adapter that the speedo cable threads onto.
these charts should help;
ID:	518516   Click image for larger version
Name:	speedo gear chart gto 69 70.jpg
ID:	518518   Click image for larger version
Name:	speedo gear chart gto 71 73.jpg
ID:	518519   Click image for larger version
Name:	speedo gear chart gto 4spd 69 70.jpg
ID:	518520   Click image for larger version
Name:	speedo gear chart gto 4spd 71 73.jpg
1970 Formula 400
Old 08-23-2019, 02:36 PM
tallyhoe's Avatar
Thank you! I dont know why i thought ames wouldnt have the part but they do. I ordered the blue 20 tooth gear. The gear i removed appears to be fine but until i compare it to a new one i wont be sure. I used the drill trick to test the speedo itself.
Guy
Lucerne 71 gto
Old 08-23-2019, 03:33 PM
unruhjonny's Avatar
As always, I'm happy to help
1970 Formula 400
