Old 10-08-2001, 08:43 AM
71 T/A 71 T/A is offline
When my 69 GTO's engine is on, the wipers only work on high speed (from the low speed position on the switch). They than turn off on the high speed switch position.
When the engine's off, the wipers only work on low speed.
I've changed three wiper motors and the wiring is correct to the motor, so it's not that. Even the switch is a new NOS piece.
Old 10-08-2001, 06:01 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
No easy answer with electrical. Are you sure you have a 2 speed motor? Check to make sure the Wiper switch is grounded properly behind the dash and then I would try another switch even though that one is new. (Unless you got the same result with the original switch)
[This message has been edited by Ccass (edited 10-08-2001).]
Old 10-08-2001, 08:48 PM
berrygoat's Avatar
berrygoat berrygoat is offline
Ccass, does PY carry the wiper switch for a 69 GTO? Ive never seen one in the catalog.
Old 10-08-2001, 10:56 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
What do the wipers do when they are selected in the "OFF" position?
"Run wild with an Indian, not with the crowd in a Chevy"
Less said,,,,,,,, Less mended.
Old 10-09-2001, 01:01 PM
CCass,
I fixed the problem! You were right. I grounded the switch and that did it.
Old 10-15-2001, 12:10 PM
Ccass's Avatar
Administrator
btw; the 69-72 wiper switch is NOT available as a reproduction.
