Comp Cams Hyd roller lifters
I've checked everywhere and Comp Cams hydraulic roller lifters aren't available at this time. I know this is very subjective, but what would be your second choice for lifters? I know that Johnson is making a limited travel hyd. roller lifter for a Pontiac but they are about $200 more than the Comps. Anybody use them yet? What about other brands?
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I bought the Lunati lifters to go with my Lunati cam cause I got them from a guy that had a stalled build for a song. My machinist inspected them and said they looked to be fine quality. He is doing the lifter bore mod anyway but Butler sells the Lunatis
Lee Atkinson is designing a custom Comp Cam for me. He said the lifters are on back-order. Supposed to be a two weeks wait. I'm waiting for them.
I just got a set from Comp about 10 days ago.Tom
Hylift Johnson A-2347SE
A-2347RE if you want variable duration. http://toplineauto.com/wp-content/up...log-2013-A.pdf
" I've checked everywhere and Comp Cams hydraulic roller lifters aren't available at this time..."
So, does that mean you've also checked with these vendors ? These sellers show to have the 857-16 lifters in stock. http://www.twperformanceparts.com/in...roduct_id=3345 https://www.amazon.com/Competition-C.../dp/B0014F6F36 This Ebay seller claims you'll get 'em by May 7. https://www.ebay.com/p/Engine-Valve-...8136907&chn=ps Last edited by ponyakr; 05-02-2019 at 03:37 PM. |
Paul K can most likely get you a set and probably at a great price.
I have a new complete set they warrantied for me. Never used. they had the s on them (newer type I guess) PM me if interested. 320.00 shipped
72 Luxury Lemans nicely optioned |
Don't think anybody will find a better price than this. |
I've gotten 2 sets of hydraulic rollers in the past couple months. One set from Paul K and the other set from Paul C.
May as well give up on the Johnson lifters right now. Paul C has been waiting for them to run another batch for several months now. They've been unavailable for that long. I was hoping to grab a set by the time I was ready to button up the current 455 build I'm working on, but no dice. Still not available and from what I understand from Paul there is no current due date as to when they'll run another batch of them. |
And from what he told me, Paul's been after them on the phone for months about it. |
Ironically, most companies use the same hydraulic roller lifter for an LS engine in a Pontiac. They just add a tie bar.
Another consideration is Howard’s.... great reputation. I run them .
PM sent, Gary
" I've checked everywhere and Comp Cams hydraulic roller lifters aren't available at this time...what would be your second choice for lifters?..."
Since it has been established in this thread that the 857-16 lifters ARE available, including a below retail price set, from a member, there is no need to consider a "second choice", is there ? |
are they the 857-16 lifters
http://forums.maxperformanceinc.com/...59&postcount=8
The reason he mentioned the "s", is because it has been posted here that, in the past, CC has substituted lifters made by Morel, when they were out of Shaver made lifters. The Morel Lifters had an "M" in the part number, and were Chevy lifters, with Pontiac link bars. http://forums.maxperformanceinc.com/...35&postcount=2 |
Virtually ALL Pontiac Hyd roller lifters except the Comp Shavers ARE Chevy lifters with Pontiac bars!Tom
So, thanks for everybody posting their second choices! Good for me and everyone else to know. I'm buying the set that one of our members just happened to have at his house so I'm good for now.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs Last edited by Gary H; 05-02-2019 at 10:22 PM. |
