Old 05-26-2024, 02:47 PM
gomowgto gomowgto is offline
Default Lug nut torque spec.
I have rally one wheels on my 67 GTO. the 1967 service manual says the lug nuts should be torqued to 65 ft lbs. Me personally, I feel that's not enough, but torque specs are there for a reason.
I found paperwork from when the rally one wheels and center caps were ordered, and it says to torque all lug nuts to 75-85 ft lbs.
My question is, what one should I follow, and why a 10 ft lb range? Thanks in advance for your help.
Old 05-26-2024, 04:34 PM
gto4ben gto4ben is offline
It sounds like you have the reproduction Rally I wheels. You'll have to ask the vendor why they recommend a higher torque than factory. Stock wheels are 55-75 lb-ft. per the Assembly manual. The 10 lb-ft tolerance is to accommodate the torque tool and friction variation.
Name:	wheel torque 67 GTO.jpg
Old 05-27-2024, 01:27 AM
You have to remember Rally wheels were also available on the big cars. They had 1/2 inch studs and the factory only recommended 70-85 lb/ft to torque them.
Old 05-27-2024, 01:38 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Thread lubrication could account for the differences, too. Not sure if it specifies or is "asterisked", but it would make sense if it were 65 ft/lbs with light oil, vs. 75-85 for dry threads, for similar clamp loads.
