'71 Formula Oil Pressure
My '71 Formula 455 HO with the Ralley Gauges has alway displayed between 40 and 60 lbs. oil pressure. The gauge started showing 80 lbs. pressure at idle, and went off the scale above idle. A mechanical gauge check showed the motor actually has between 40 and 60 lbs. pressure.The electrical sending unit shows 88 ohms at idle.I installed a new sender with the same 88 ohm reading.The Ralley gauge shows 80+ lbs. pressure with both the original and new sender.A variable resistance check of the gauge through the existing gauge wires shows normal gauge travel between 10 ohms and 80 ohms (gauge seems to read approx. one pound of pressure for each ohm measured (10 ohms approx 10 lbs...80 ohms approx. 80 lbs.). Is it possible both sending units are faulty? Any ideas on this? Thanks for any help.
According to the service manual, the oil pressure gauge will show 0 PSI at 1 ohm and 80 PSI at 88 ohms. It sounds like you have a faulty sender. The quality and accuracy of aftermarket sending units has been questionable recently. I don't know if they're being outsourced to China or Mexico or what???
What, if anything, have you done to the car recently? With the original and new sensor showing the same thing, I would question another sensor being the solution. Maybe both sensors are bad. Unless you have somewhere around 80+ ohms of resistance between battery negative and carbody? I measure 3.5 ohms between sensor and carbody with the car dead. Has your water temp guage showed anything different recently? Bad parts out of the box really throw a wrench in a guy's troubleshooting.
Jeff Schneider Alliance, NE |
Thanks for the help.To explain further,I had done nothing to the car before the oil gauge went south on me.I am pretty much toward the end of a 4 year resto on the car.It's garaged and has been driveable for almost a year,but has not been driven (registration,insurance,lights not installed yet,etc).But I do run the motor weekly.The oil pressure gauge has always read normal.Last week while I was running the motor and watching the gauges,the oil gauge jumped to 80+ lbs.I did check the ground resistance with engine off as suggested and got less than 2 ohms.It must be (I hope) that the new sender is also bad...I'm taking it back to Classic Industries tomorrow for a swap.I'll let you guys know what happens.
And the temp gauge reads normal...
Temp senders and pressure senders are known to be crap from aftermarket. Get your temp sender from Electric Limited. I believe I got my oil sender from Napa and it was OK but my Napa and other source for temp sender were way off, as much as 20+ degrees. Do a search for more info on these topics in this forum and the electrical forum.
'73 Buc Red T/A, 4 speed, A/C, Std Black Interior "If you choose not to decide, you still have made a choice" RUSH (Freewill) |
Thanks! I had another referral to "lectric limited" as well. I have already ordered one of their senders. I'll let you know what I find.....
FYI, the original sender was reading high, like 230 warmed up, and this was before AND after hot tanking the block and heads, a recore of the rad, new stat and a rebuilt cast impeller water pump. I decided to try a new NAPA sender and it is even worse! Goes to 250 when the stat housing is 195 (with infrared). |
Giles- I have a feeling you will end up having to get a used original temp sender.That is exactly what mine was doing. I, too, have heard of electric limited,I bought one of their senders for my car. Still have it if you want it. It has a blade instead of a peg like the OEM ones were . I also have two or three aftermarket peg ones, none worked. You see the originals on Ebay every once in a while. I recall the one I bought came off of a GTO. Email lilgto447 on Ebay.Fred is his name. I bet you he has a few originals. He is a nice guy and is always parting out Pontiac engines and has a box full of used senders at all times..
PM me and I can give you his telephone number. I bet he will sell you an original for $15 or so and your problems will be gone. |
I'm curious to see if original used units fix the two problems described here. My oil pressure gauge on the '73 went south just after getting the car. Its pegged all the way to the right. I bought a new sending unit from Bulter Performance and was planning on installing it soon. Would like to save myself the hassle of doing it twice if its going to be way off and I have to get a used one.
Jimmy www.firebirdgallery.com 2002 WS6 M6 Trans Am - original owner 1973 Trans Am 455/4-speed 1971 Formula 400/400 1969 GTO 400/400 - 3rd owner 1968 Firebird Convertible 350/200R4 POCI - AAC |
I have seen a ground issue with the cluster cause more ground than it needed and affect the showing reading
