Washer Bottle Application
I need a windshield washer bottle for my 1971 Formula. There is a bracket up front on the left inner fender by the battery. The holes in the bracket are about 4 1/2 inches apart. One catalog lists a bottle for a 1970 car. Another vendor lists one which fits 1970-1975 models.What's the deal on these washer bottles (I have the original cap and hoses). Thanks for any help.
I purchased the washer jar for my '72 Formula from PY. PY Firebird catalog lists it for '70-'74 models, and it's perfect.
PY part number RPE220. $29.00 and is supllied with the cap and filter.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
They were still available through GM as of last year or so. When viewing them from the front, the original early ones had square bottom (with rounded edges). The ones that you get now look and fit identical except one of the bottom corners is cut off at a 45 degree angle. I think the mid/late '70s cars needed it to be cut to make room for something so that is the way GM has been making them since. The ones you are looking at are probably the same, GM. I have not seen a repop of the correct early ones anywhere.
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
GM part #3990892
