1969 400 engine
I am selling a 1969 400 engine. The bad - spun a rod bearing and ceased the #6 rod to the crank. The good - This happened at idle so the damage is limited to the crank and rod. It is a WT 641154 block with #62 heads 0089. It has a Comp Cam H292 cam, bored 30 over with TRW pistons, comp cam 1.5/1 roller rockers. Complete engine except carb and distributor. Give me an offer. Pick up only. I'm 40 miles south of Chicago. Thanks.
Per forum rules you must post a price.
Price
Alrighty then. $600 obo
$400-Can pick it up this week.
Greg - just sent you a message.
Here are some pics
You can see the discoloration where the #6 rod bearing ceased.
Does it include any pulleys, brackets, oil pan or valve covers? If still available send me a PM. Thanks, Ron
It includes oil pan and valve covers. I also have the fuel pump which is not currently on the engine. No pulleys or brackets.
Still available!
offer still stands.
Just curious...
shouldn't a '69 WT sport 48's?
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
Yes it SHOULD .
Still available
Still available. $550.
Here is some more info. Comp cam P286AH-8 cam. Erson dual roller timing chain. TRW L2256R30 pistons. Valve job done 6,000 miles ago. |
Still available. $500
