Old 10-05-2006, 08:42 PM
pontiacphil pontiacphil is offline
Question Column Mounted Tach.?
I would like to install a tach. in my 67' GTO just to keep an eye on my RPM's. Not a racer so a 6,000 or 8,000 RPM tach. is probably what I need. I would like to mount it on my steering column in front of the dash guages. I have a HEI distributor so I need one that works with that. What is a good brand, model of tach., that would fit on my car and give good results? Where's the best place to buy one?
Old 10-06-2006, 11:23 AM
MrPushrod's Avatar
MrPushrod MrPushrod is offline
call summit, they'll have everything you need. try ext. 5842, my good
friend works there, his name is "gage".
Speed kills, buy a honda.
Old 10-06-2006, 05:26 PM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
An Autometer Sport Comp in about the 3" is small enough to not be as visible as the monster 5". You can use two large radiator clamps to secure it's bracket to the column.
Old 10-09-2006, 12:24 AM
Old Man Taylor's Avatar
I used the Autometer Sport Comp.
Name:	GTO Interior 2.jpg
Old 10-09-2006, 09:33 AM
Half-Inch Stud's Avatar
Factory Chrome Tach mounted using a pair of (4" or 5") stainless hose clamps and some felt.
because it is a 67 GTO.
Old 10-10-2006, 02:14 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Or a rubber strip cut from an innertube.
Old 10-10-2006, 08:41 AM
yea, the rubber strip will help stabilize the mount & not be paint scratchin.
