Old 10-19-2008, 04:05 PM
pontiacphil pontiacphil is offline
Question What Size Tire For 67' GTO?
I've spent a couple hours searching old posts about the size tire I need but am still a bit uncertain what size to buy. I currently have Rally 1"s, 14 inch, with 20 yr. old Goodyear 215x70x14 tires. I want some larger, 15 in., wheels & a bit more rubber "on the ground". I can get a set of Rally 2's, 15x7 in., without tires. My GTO is a convertible with stock suspension. I'm going to purchase new tires, probably Goodyear or Goodrich (any suggestions?) I don't want any rubbing/scrapeing with the new tires. What would be the best tire size to mount on these wheels? Several posts here say 235x60x15 for the front & 255x60x15 for the rear. I'm afraid this size might be a bit too wide and I'll encounter interference/rubbing problems. Any info. you can provide will be appreciated.
Old 10-19-2008, 05:50 PM
wytnyt's Avatar
wytnyt wytnyt is offline
here
http://forums.maxperformanceinc.com/...archid=1356640
Old 10-20-2008, 11:06 AM
Default WYTNYT, Can't Get Thread To Open.
WYTNYT, Thanks for the response & info. Only problem is that when I click on the thread you provided I get: "Sorry, no matches". Is there any other thread I can get info. about the correct tire size for my 67' GTO? Thanx.
Old 10-20-2008, 01:02 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
A 215/65 15 and 235/60 15 are real close to the same height as the 215/70 14 (26"). a 255/60 would be 1" taller if you wanted to go with a bigger tire on the rear. the 215/65 is pretty much the same size widthwise also as the 215/70 14. there is also 245/60 15 in between, I had those on the back of my 66 with some coke bottle daisy wheels.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 10-22-2008, 01:15 PM
chipster's Avatar
chipster chipster is offline
I would go with 215-65-15 on the front, 235 or 245-60-15 on the rear. 255's would really look pinched on a 7 inch wheel.
Right now I have 235-60-15 BFG TA radials on the front of my 67 LeMans, they scrape sometimes if I hit a bump while the wheel is turned.
Old 10-22-2008, 01:50 PM
kookykrispy's Avatar
kookykrispy kookykrispy is offline
I am a fan of big meats out back and I can fit 275/60r15 on 15x7's and they are quite snug but just fit, tucked right under the fenders on my 67 gto. If you do this, you'll have to roll the fender lip under and carefully cut back the stainless wheelwell trim so the fenders won't cut up the tires. Make sure you have the earlier rear end... 68 and later rears were 1/2 inch wider on each side and when fitting massive meats it makes a a difference!
My fronts are 215/65r15
"Keep your foot hard on that pedal
Son, never mind them brakes
Let it all hang out 'cause we got a run to make!"
Old 10-22-2008, 03:15 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
I'm running a 275/60-15 on the back of my '67 with 8" Weld wheels with a 5.5" backspace. No clearance issues whatsoever. Didn't trim or massage anything. Have also ran 265/50-15 with zero problems.
My '67 4 dr is running 7" Rally 2s with a 265/50-15 - Zero issues whatsoever.
Old 10-24-2008, 05:42 PM
GTOGreg's Avatar
GTOGreg GTOGreg is offline
I have this exact tire combo you mention. My front wheels are 15X7, the rears 15X8. I am running Firestone Indy 500's. It is the set in the pics below...
1967 GTO
Tyrol Blue/Blk Cordova
400, TKO-600, 8.2 Posi w/3.55
400 + .020, decked to .005
SD Performance 240+CFM 670 heads
RARE HO/RA manifolds
RARE 2.5" Exhaust (18" Magnaflows)
SD "Stump Puller" HR cam (230/236, 112LSA, 107.5 ICL)
PRW stainless 1.52 roller rockers
Forged TRW slugs
SCAT H-Beam forged rods
Old 10-24-2008, 06:56 PM
carcrazy carcrazy is offline
I currently have 15x7 rally 2's with 235 60's on the front and 245 60's on the rear-no problems.
Old 10-24-2008, 07:25 PM
judgeman6970's Avatar
judgeman6970 judgeman6970 is offline
im running 255/60x15 bfg's on 7" wide rallye II's...they fit very nicely.....
2006 GTO/silver, 1969 Judge/Carousel Red, 1970 Judge/Black, 2002 T/A CETA.....
Old 10-31-2008, 08:46 AM
nodwyer's Avatar
nodwyer nodwyer is offline
Here are some shots of my 66, 15x7s 215x 70 on front 235 x 70 on the back
ID:	147041   Click image for larger version
ID:	147042   Click image for larger version
