Old 11-19-2021, 03:03 AM
po65to po65to is offline
Default 64 GTO Power Antenna Switch
Looking for a 64 GTO power antenna switch for the dash, and pictures showing where it is mounted on the dash. Also pictures in the trunk of power antenna unit and how it is mounted.
Old 11-19-2021, 03:06 AM
Also looking for the chrome pieces that go on top of the rear quarter for the rear power antenna.
Old 01-16-2022, 02:12 PM
tallrandyb's Avatar
tallrandyb tallrandyb is offline
https://forums.maxperformanceinc.com...13#post5680313 is a great thread on this.
I just saw the Hurst GeeTO GTO and the Riverside 500 GTO at Mecum's auction, one with only power antenna and one with reverb and power antenna, and it showed the antenna switch aligned with one dash screw when standalone, and has the reverb in that spot with antenna to the left when you have both.
ID:	582067   Click image for larger version
ID:	582068   Click image for larger version
Old 01-18-2022, 07:37 PM
Jonsie Jonsie is offline
Looks like I have one, have both the switch and bezel. Someone wrote (4-5) on underside of bezel. Bezel is like NOS. Are '64, '65 set-ups the same? Unsure. PM if interested
Old 01-18-2022, 11:23 PM
OG68 OG68 is offline
Scroll down the page a bit. It shows the power antenna switch mounted under the dash.
http://wildaboutcarsonline.com/membe...es_FO_16IP.pdf
2007 Cadillac SRX
Old 01-18-2022, 11:36 PM
Yep, bezel's the same
Old 01-20-2022, 11:25 PM
So are ya still looking?
Old 02-18-2022, 07:54 PM
Default 64 GTO Antenna Switch
I did not get a notice of this response, but am still interested in the power antenna switch and bezel for 64 GTO.
Old 02-18-2022, 08:57 PM
Sold
Old 02-23-2022, 03:27 PM
Am still looking for a power antenna dash switch for 64 GTO.
Old 02-23-2022, 06:27 PM
tallrandyb's Avatar
Wow power antenna switch totally different for 64 and 65, I didn't realize, I had never seen the 64 switch before.
