Old 09-01-2018, 12:53 PM
67428HO 67428HO is offline
Lightbulb POA valve 68 GTO
How can you test a POA valve before installing on to evaporator ? Thanks
67428HO
Old 03-25-2019, 09:59 PM
How does one know if this is good or bad on a system that has been off for years (by previous owner)?
Old 03-26-2019, 03:22 PM
Tim68bird Tim68bird is offline
Unfortunately, there really isn't a reliable way to test without installing and attempting a charge. There is one way to determine if it's NOT good, and that would be to block off the 3 ports on the side of the valve and see if you can blow through it. If you can, it's no good. If you cannot, there's a possibility it's still good. If it's not good, you can go to Original Air and they can rebuild yours as long as it's an original style valve. They also sell valves to eliminate them.
Old 03-26-2019, 06:53 PM
LATECH's Avatar
LATECH LATECH is offline
https://classicoldsmobile.com/forums...libration.html
Old 03-26-2019, 08:58 PM
Cardo's Avatar
Cardo Cardo is offline
I ended up going this route. Eliminate all doubt and headaches. https://www.shopcenturyautoair.com/s...it_POAELM.html
"I know just enough to keep me here, but not enough to get me out"
