Old 04-06-2006, 07:46 PM
ta-kid ta-kid is offline
Default !7 inch AR sc200s wheels
Well I just ordered my 17 inch x8 for the front and 17 x 9.5 for the back,with 5 inch backspacing for the front and 5.5 for the back.Going to lower the car 2 inches all round.After looking at what "Streetking" had done it should fit ok,I hope,as its a six week custom order and I am stuck with the wheels if they don,t.I don,t know if "Streetking "had to any other mods to make them fit but I hope not.Going to use 255/50/17 out back to keep the stock tire hieght of 27 inches so thr speedo still reads correct and 225 up front.Any comments or suggestions.
Old 04-06-2006, 07:56 PM
Larry Navarro's Avatar
cool wheels!!
Old 04-06-2006, 08:59 PM
The stock tire height on a '70-'72 is closer to 26 inches.
FWIW
Old 04-06-2006, 09:07 PM
Well,what I have researched on the stock 71 tire, a F70-15,Is they are 26.9 inches tall.Also I am running the performance option,a 3:73 rear gear,so a little tall will help make it more tolerable cruising.
Larry, yes those are the wheels you posted but since my car is close to the lucern blue,I have ordered the wheels with the light gray spoke option on the spokes.I thought they might look a little more striking on a blue T/A.
Old 04-07-2006, 08:31 PM
Stock '71 tires would have been F70-14, or F60-15. No F70-15.
27" tires may well work fine on your application, but they're taller than stock by about an inch.
Old 04-07-2006, 09:38 PM
Norwood's Avatar
Norwood Norwood is offline
Thumbs up
I had 15" 200s with grey spokes on my blue 70 ta for years. they look great
Old 04-07-2006, 11:41 PM
I stand corrected.71 t/a's came with f60-15 a 25.9 inch tire.Sorry Kieth,looks like you were right.I may have to re-think my tire size options.
Old 02-08-2014, 01:44 AM
Formula8's Avatar
Formula8 Formula8 is offline
Here's mine. 17 x 8s all around. 5" backspace up front with 1/2" spacer 245/45-17. 4" backspace, 255/50-17 rear.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 02-08-2014, 03:06 AM
transam1972 transam1972 is offline
Default S.C.C.A.T/A
I like your choice of S.C.C.A. red!!
Old 02-08-2014, 08:44 AM
Norwood's Avatar
This thread is from 2006, did this ever get done. We would like to see some finished pictures. Here is a back in the day photo of my 70 with its 200s wheels
Old 02-08-2014, 10:40 AM
Formula8's Avatar
Weird. I didn't resurrect that. It showed up as current when I read it. Sorry.......some folks will use any excuse to post some picks of their ride eh?
Old 02-08-2014, 11:10 AM
Norwood's Avatar
Ya but it looks pretty cool.....
