View Poll Results: Poll question
easy to install 2 33.33%
needed little modification 0 0%
needed lots of modifacation 2 33.33%
problems not fixed 0 0%
total P.I.T.A. 2 33.33%
Voters: 6. You may not vote on this poll
Old 07-19-2004, 08:14 AM
Darrell's Avatar
Darrell Darrell is offline
Cris has said he has the problems fixed with the 70 a body X system. Question is-
*In your opionon is the X system on a 70 GTO....
ET 12.504
MPH 107
3940 lbs
Darrell's Avatar
ET 12.504
MPH 107
3940 lbs
Old 07-19-2004, 09:57 AM
Half-Inch Stud's Avatar
I voted it a Total PIA and the results show 0 votes.
HIS
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 07-19-2004, 10:01 AM
Oh, I get it.
Butt, I still don't get the Pypes fit:
Tailpipes hang low after rear tire.
Tailpipe goosses hit frame when I raise the tail exits to rea bumper.
Mufflers point straight ahead, while they fit may be best if they angle toward the drivershft.
Header pipes are farther apart or too pidgeon-toed from X unit, depending on X-unit flip.
Presently the whole system is suspended, but nothing is aligned for fit-to-be tight. I'm afraid to tighten anything until I know the system will close.
HELP!
HIS
Old 07-19-2004, 10:08 AM
Darrell's Avatar
When did you purchase yours HIS
ET 12.504
MPH 107
3940 lbs
Old 07-21-2004, 08:26 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Half-Inch Stud:
HIS <HR></BLOCKQUOTE>
Mark, You're an engineer aren't you? You should be embarassed. Bring the car over and we'll get you going.
