Old 01-25-2023, 08:41 AM
Jromaine87 Jromaine87 is offline
Default 535 IA2 Build
Yesterday was dyno day!
Alrighty guys! I built this bad boy, and since it is my first one( had adult supervision) I’ll just be happy if it all stays together. I’ll use this post to comment on our pulls. We should be making a few
First well start with the same setup as I had previously,
2.125 in headers with the 1450 AED Carb, then we will switch it up a bit,
I will look for peak power up around 8000 ish if needed but also looking for a good combo to bracket race with.
For all that don’t know.
It’s a 535 IA2 Aluminum block
4.350 bore with 4.5 stroke
Racetec Pistons
14.75-1 compress running C16
Jessel Mohawk System 1.8 Rockers
Cam is a big boy
Intake, Heads are All Pontiac Tiger heads
No flow work done but been port Matched
409 CFM at 1.0 Lift (.936) is where I’ll be.
Custom 2 piece Moroso Langer Pan
Msd crank trigger
Looking for 900 ish
Clearview oil filtration with system one backup filter.
Dyno Results
Peak HP
887 at 7000 RPM
729 TQ at 5500 RPM
I made 887 with no vaccum,! I made one rookie move, didn’t think to ask about a pan gasket, I just beaded it up with black gasket maker and called it a day, apparently there is a cork that goes into the rear main that I missed. Caused us to have no vacuum. Easy fix.
I can only assume with a sealed up engine I would make around 905-910. There is plenty of room to grow.
Wish I could add videos for all who don’t follow my Facebook post!
Old 01-25-2023, 09:23 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job! Thanks for sharing.
Go fast, see Elvis!
Old 01-25-2023, 12:32 PM
25stevem's Avatar
25stevem 25stevem is offline
If you had no oil leak back there at 7000 rpm I bet you had the main cap arch sealed up anyway, but maybe just by a hair!
I do stuff for reasons.
Old 01-25-2023, 01:37 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Gave up fighting with the cork years ago, all pans are not created equal. I just use a tall bead of sealer in the back of the pan, it works well.
Dave Polichena
Old 01-25-2023, 02:02 PM
Oh there was oil coming out. [/IMG]
Old 01-25-2023, 03:12 PM
mysticmissle's Avatar
nice job thats healthy especially for an aluminum block.
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 01-25-2023, 07:19 PM
I guess I would have applied enough sealer if I knew I needed to lol. I had no idea.
Old 01-25-2023, 08:47 PM
slowbird's Avatar
slowbird slowbird is offline
Congrats! It's awesome that you built it, bet that feels really good.
Old 01-25-2023, 08:54 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
Sweet motor!
Old 01-26-2023, 09:16 AM
Don 79 TA Don 79 TA is offline
nice setup, sorry about the leak ordeal
any chance you have a weight on the total setup?
Old 01-26-2023, 05:58 PM
Scott Stoneburg's Avatar
Very nice! Congrats on building it yourself.
Old 01-27-2023, 09:42 AM
Thank you!!
Old 01-27-2023, 01:27 PM
Bill Eveland's Avatar
Great numbers, at least the dyno saved you pulling the engine back out of the car to fix the leak.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 01-27-2023, 04:46 PM
ChiefCrazyCanuck ChiefCrazyCanuck is online now
Excellent numbers. What will be 900 + HP in the car is fantastic.
Old 01-27-2023, 06:36 PM
Nice!
Old 01-28-2023, 12:41 PM
aaronman aaronman is offline
Great job James! Fun to be part of the adult supervision! ��
The Following User Says Thank You to aaronman For This Useful Post:
