Old 04-21-2013, 10:57 AM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
Default Transmission cooling
I like to race in multiple classes when I go, so, I have a routine for my engine temp that allows me to run multiple classes (hot lap if I'm that lucky). This involves an electric water pump and two electric fans as well as a good cooling system.
What I have not found is a good way to keep my transmission temps down. After a few rounds, my temps get over 200 degrees, and it seems to cause reaction time issues (terrible lights)
Has anyone put in a pump that will circulate transmission fluid in the pits/or as auxilliary to allow for quicker cooling of the transmission fluid without the front pump turning.?
Any other ideas or fixes to get rid of this saturation? - Bill -
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 04-21-2013, 12:36 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Bill, I have heard this Meziere Trans pan works well. I know of quiet a few guys that are using it and are eliminating there trans coolers with some sucsess
In a nutshell it's a trans pan that has coolant passages that uses coolant to cool the oil in the pan. Catch is you have to plumb lines off of your water pump (pres & return).
Here is the link. Just a thought.
http://www.meziere.com/ps-1481-1494-wtp300.aspx
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 04-21-2013, 12:50 PM
Probird's Avatar
Probird Probird is offline
What kind of transmission Bill? Here is one for an for a Powerglide. http://www.atiracing.com/products/tr...arts/scs30.htm
Here is another article: https://www.google.com/url?q=http://...vqxaPtH8hZMD3A
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 04-21-2013, 12:54 PM
Bill Meyer's Avatar
Jason - That is an interesting concept.-. Bring the cooling to the pan. While I do have a T-400 if it catches on, it wont take long for someone to build more sizes and types.
I was more thinking in the lines of getting the fluid away from the pan and to a fluid radiator with a fan, using some kind of pump. Kinda like a transfusion for a transmission.
Where I seem to have the problem, is after 5-8 time trials, and two to three rounds, I just can't get the tranny to cool off.
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 04-21-2013, 12:58 PM
Probird's Avatar
Tilton also makes an inline pump: http://tiltonracing.com/sites/default/files/editor_uploads/files/98-1901%20%28Diff%20pump%29%283%29.pdf
Don't know how well it works though.
Old 04-21-2013, 12:59 PM
Bill Meyer's Avatar
Probird - thanks for that link as well!! Thats kinda what I was thinkin' - now I'll just have to get a PG. But wait, now I'll need a bigger engine so I can carry the front end, but wait....... love this endless quest!!!! - Bill -
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 04-21-2013, 01:28 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Good thread bill. I'm in the same boat with my TH-400
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 04-21-2013, 08:40 PM
aaronman aaronman is offline
Some interesting ideas on this thread from very $$ to simple.
http://drr.infopop.cc/eve/forums/a/t...506#1047050506
Old 04-21-2013, 09:41 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
Bill--
Just thinking outloud here, since it wasn't mentioned, but:
1-Is the cooler big enough?
2-Does your cooler have a fan on it as well? They do make them.
3: Does your cooler have constant airflow to it like a radiator should?
Again, you didn't mention so I am just asking.. We have done these above, as well as wrap lines with heat protective covering if they are near exhaust or headers, and like previously mentioned, run/fabricate some sort of cool can inline with dry ice or fluid...But what I have found is the basics Like I have mentioned above were enough to keep things cool enough, even running hot lap rounds..
Old 04-21-2013, 10:01 PM
Bill Meyer's Avatar
Thanks for all the links guys - there sure are a lot of ideas out there!
I do have two coolers, one in front of the radiator and one tie wrapped to the bottom of the radiator. They are in series. I dont go up on the limiter until the top bulb comes on. I have used a fan in the pits, the carpet drying kind, but once the tranny gets over 200 degrees, it just doesn't cool off fast enough. I really want to circulate the fluid when the car is off. I saw several products on the links that would do this....Bill.. I also have a deep finned pan.
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 04-21-2013, 10:11 PM
Having the fluid circulate with the car off and have an electric fan cooling it would be ideal like many do with their cooling system between rounds and on street cars. Cools down real fast. If you can make that happen, problem solved..
I was actually referring to an actual cooler with an electric fan attached to it, while running and making a pass and idling. They make dedicated coolers with their own dedicated fan attached to it..if it got real expensive to run a pump in line as well, this may be a good alternative as Trans coolers help dissipate heat at low speeds but do their job at higher speeds, at lower speeds, the fan comes into play to keep it cool..Just a suggestion and what has worked perfect for us in the past..
Old 04-22-2013, 02:45 AM
Badbird69's Avatar
Badbird69 Badbird69 is offline
Just quit going rounds, you Wally Hog. The transmission will stay much cooler.
Old 04-22-2013, 05:28 AM
S/st 54's Avatar
Bill, I realize you are running a t-400 but here is another option for a powerglide
It has a external trans pump and cycles the fluid with the engine off!
I know just about every pro mod guy out there that is using a converter is using something to cycle trans fluid through a cooler in one way or another.
I'm sure with the turbo guys going to the Turbo 400 case I'm almost certain something is available for what your wanting to do.
Old 04-22-2013, 05:44 PM
Pumping oil from the pan to a separate cooler/fan assy then return to trans should be adequate.
Old 04-22-2013, 06:56 PM
cgeise's Avatar
cgeise cgeise is offline
I looked into this issue A LOT when having trouble with the turbo cars trans - th400 - turned out not to be cooler related but did learn a lot. I now run my trans cooler lines thru an ice bath as the air cooler type we use are maginally efficiant. you can do it via the regular cooler lines or plumb seperate lines in and out of the pan to a cooling coil in an Ice box -- Id be glad to talk to you as my typing here sucks -- Curt
Old 04-22-2013, 06:57 PM
ry57pont's Avatar
ry57pont ry57pont is offline
or get rid of the auto, and go 4-spd!!
1970 gto (4spd) 462 500 hp
11.940@114.21 / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 04-22-2013, 08:22 PM
Formulas Formulas is offline
There is small 12 volt fans that you could put directly on a cooler,
get the cooler off the radiator so the fan can blow directly on the cooler in a dedicated manner
the ones i have are similar in build as in the link but mine are about 6 inch square many in this link are just to small the link is just to provde a reasonable facsimile
http://www.amazon.com/s?ie=UTF8&page...qid=1366677020
Old 04-27-2013, 01:36 AM
lust4speed's Avatar
If you can keep the trans fluid from reaching the high temps to begin with, then additional cooling might not be necessary. The stacked plate type cooler does a much better job of dissipating heat. I run two of these in series: B&M Trans Cooler
Mick Batson
Old 04-27-2013, 10:37 AM
Bill Meyer's Avatar
Thanks, everyone for the many ideas and links. I think for now I will do as Mick and others suggest and get a much better/bigger cooler w/fan. If that wont do it, I will reinvestigate getting the fluid away with the ability to circulate without the car running.
Thanks to PY forums for allowing us to get these ideas out there!!! - Bill -
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 04-27-2013, 03:29 PM
fwiw... I just tested an old holley red pump in the shop... it moved cold tranny fluid just fine... just recirculated it back to the jug but did use about 8 ft of hardline and hose... I let it run 10 minutes... pump didnt seem to get very warm... I even got it to pull oil from long end with no trouble...
Dont have a clue how it would hold up at high oil temp but might be an option worth further testing.
