Old 09-30-2024, 05:14 PM
rsworden rsworden is offline
Default Hood Tach light
Just installed my new Ames hood tach. Noticed that there is no light. Did I miss a step. Everything works correctly, just no light when I turn the lights on. Any ideas? Thanks everyone.
Old 09-30-2024, 08:07 PM
tstroud tstroud is offline
You have to run a wire to the fuse box. Usually the light comes on with the key switch.
Old 09-30-2024, 08:42 PM
4dblnkldude's Avatar
Yes, the repops are on all the time.
Old 09-30-2024, 11:37 PM
DOC DOC is offline
I changed the bulb to a red led. Much easier on the eyes at night
The Following User Says Thank You to DOC For This Useful Post:
Old 10-01-2024, 11:34 PM
Joe's Garage Joe's Garage is offline
Default My 1970 Judge hood tach lights up whenever the key is 'ON'.
And it's factory-installed, so I think it's correct.
Old 11-12-2024, 08:05 PM
Default wiring tach
The tach harness had three wires. Once to ground, one to the coil, and one to the fuse box. All three are hooked up and the fuse box one is hot with the key on. Still no light. I'm wondering if the bulb could be bad or if the tach is somehow defective. Did I miss anything anywhere?
Thread Tools
Display Modes
