Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
I'm learning about a dt466 and swapping from the MT545 Allison to a manual trans. I think I've learned that medium/heavy duty engines use different sized "clutch housings" to mate to different sized "flywheel housings". These housings are categorized by SAE numbers. I think the MT545 mates to an SAE #3. I found a local 10 speed, a Meritor MO16G10CM16053 for sale. It's probably a #1.
Does anyone know way more about this than I do? Could you teach me? Would anyone have link to gear ratios for the above transmission? (I've googled 'till I'm cross-eyed and confused.)
A conclusion is the result of analysis of information: sound logic must be used, as well as accurate, applicable information. |
I'm on a couple truck forums where they might be more knowledgeable.
https://67-72chevytrucks.com/vboard/index.php https://www.gmsquarebody.com/ You might try asking your questions there. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.56 @ 139 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
FWIW, I found enough info online that I managed to call a truck salvage/repair yard with reasonably intelligent questions. The DT466 started as purely mechanical, then went to HEUI around 1995. Like some auto makers, the old stuff carried on for a while, yet it had some newer upgrades. My engine is a 1996 dt466 NGD, and is a purely mechanical engine, yet has the newer HEUI style flywheel housing and flywheel bolt pattern.
If anybody needs to cram one into a Pontiac, you can ask me for more details. (466 CID, turbocharged, and came under a one piece fiberglass tilt front cap. Sounds cooler than a school bus if I say it like that, huh?)
Thread Tools | |
Display Modes | |
