Old 06-23-2021, 06:20 PM
steve's Avatar
steve steve is offline
Default washer reservoir mount.
can anyone show me where/how the original washer bottle mounts in an 8? I'm finally getting the system running and have nothing to compare to. I think I have the right bottle and bracket.
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers....
Old 06-24-2021, 01:47 PM
I'll try and get one this weekend if someone does not post one before then.
Old 06-24-2021, 06:46 PM
steve's Avatar
thanks that would be awesome. this is what i have and I'm not sure its right.
ID:	568783   Click image for larger version
Old 06-24-2021, 07:56 PM
No, that's not original even if it works, unless a weird 1981 thing, haven't seen it before or how it would mount. I meant to add a pic and forgot. It's similar to the overflow bottle being a bracket strap, nuts secures to bottle and u-nuts on the feet with bolts up through the inner fenders.
Pretty sure you can get them in repro now, wasn't always the case.
Old 06-24-2021, 08:14 PM
I think Camaro used that type, Firebird usually have the strap bracket similar to the overflow bottle. The jar screws onto it and has u-nuts on the feet, fender bolts up through the inner fender.
I meant to post a pic and forgot. Not sure if 81 used fancy features like the overflow bottle alterations, will check.
Old 06-25-2021, 04:01 AM
Confirmed as 77-81 Camaro washer bottle bracket, bottle suits either model.
Different bottles in pics but same bracket fit most, available repro and used. Bottom pic shows the U-nuts used to secure up through inner fender.
78 Washer Bottle bracket 1 by Aus78Formula, on Flickr
washer bottle pulse2 by Aus78Formula, on Flickr
Washer bottle and pump1 by Aus78Formula, on Flickr
Old 06-27-2021, 11:35 AM
steve's Avatar
thanks guys that helps a lot !
