Old 02-14-2021, 07:54 PM
grd777 grd777 is offline
Default ready to install my core support ,rad and shroud
anyone have some good tips before i start . never done one on a firebird
thanks
Old 02-14-2021, 10:01 PM
Formulabruce's Avatar
Watch This >> https://www.youtube.com/watch?v=t9DtbP4ez2A
and This > https://www.youtube.com/watch?v=bHJLaqe-qnQ
Make sure you did your subframe alignment measurements. This is critical
Always work from Back to front with sheet metal alignment.
When just core support is on, use Bungie cords to hold it up while you work, as it leans forward with no fenders in place.
Slide core support to the LEFT as you face the front of the car to get started with alignment.
This is Not a quick and easy procedure . Good luck !
ALIGN it all before you add the radiator, etc as you will have to take it apart possibly to nail down the front end sheet metal,.
The Following 3 Users Say Thank You to Formulabruce For This Useful Post:
Old 02-14-2021, 10:17 PM
thanks i saw those vids before thanks for the tips
Old 07-05-2021, 11:48 AM
cnc's Avatar
cnc cnc is offline
How many washers are typical for adjustment or something to start at/with …or is there huge variation
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 07-05-2021, 12:12 PM
watch the videos above.. .....
Old 07-05-2021, 12:39 PM
cnc's Avatar
cnc cnc is offline
It won’t play on my iPad…..should have mentioned that
Old 07-05-2021, 07:04 PM
cnc's Avatar
cnc cnc is offline
Ok got it to work I see only 2 washers in your video..... I've got 4-5.....no wonder my hood won't close if 2 is the standard ....it' sets the support too low with that many washers
Bruce maybe I missed it but how thick are those washers
Old 07-07-2021, 07:16 PM
cnc's Avatar
cnc cnc is offline
Bruce I also see u say slide the core support to the left when facing the car ....why to the left to start alignment....curious ....
Old 07-07-2021, 08:23 PM
Because this aligns the hood latch correctly, which doesn't have much adjustment, and the top of the fenders do have slots .
once hood is down, you'll see what I mean, the gaps will get you going correctly to a degree.
Your Radiator hose clamp clearance will be minimal, so rotate it where you can get access.
Good luck !
Old 07-09-2021, 07:34 AM
cnc's Avatar
cnc cnc is offline
George .....how u making out with your adjustments....?????
So just to confirm in your process,,,,
Fenders loosely attached at the cowl and core support , core support also loose slid to the left(facing the car) and then begin alignment process of panels ...hood lastly installed.....and I see the hood latch has minimal adjustment as it really doesn't have any space once inside the hood latch opening....it looks like it more or less moves the hood into a wanted position when adjusted
Old 07-09-2021, 09:36 AM
ALL restorations on all cars are built from the REAR to the front.
Align door to ( fixed) Rear quarter and rocker
Get rear of both fenders close to being flush and gaped
Keep in mind your hood hinges bolt to the Fender only so bottom of fender should have at least 1 bolt to start, the rearmost one.
Slide core to left and snug the bottom to the lower subframe with 2 washers in place.
put the L brackets on and rotate them up and snug for starters.
Old 07-09-2021, 12:25 PM
cnc's Avatar
cnc cnc is offline
Yes Bruce .... I understand that it all starts rear to frt ....thanks for the core support tip though didn't realize that
