#41
Old 07-20-2021, 06:01 PM
Dragncar Dragncar is offline
96 heads right here ,300$.. Will solve your problem.
https://forums.maxperformanceinc.com...56#post6266056
  #42
Old 07-21-2021, 01:39 PM
Formulabruce's Avatar
MTBE was Much more dense than Alcohol is , so YES, it was easier to make this work in the 90's.
While alcohol does have a higher octane, its not Dense, so More heat is on its way, which doesn't help with knock, or ping.
  #43
Old 07-21-2021, 02:00 PM
69hardtop 69hardtop is offline
I have a 1970 455 D-port with 64 heads. When we rebuilt it I went with a 15cc dish piston and a 068 Melling cam. My heads cc’d our right around 89-90 so my calculated compression is mid 9’s or so. I run 93 octane all the time with no issues, never really tried anything with a lower octane. I did have it balanced also. It’s pretty smooth, plenty of torque and pulls hard…I was criticized for not going with a more aggressive cam profile but I’m super happy with results
The Following 2 Users Say Thank You to 69hardtop For This Useful Post:
  #44
Old 07-21-2021, 02:40 PM
People love to say you didnt build in enough power, but THEY dont buy the gas or pay for the added problems it can cause, especially for a fun driver.
what T stat you run?
  #45
Old 07-21-2021, 02:56 PM
I run a 180 degree thermostat, fan shroud and Hayden heavy duty clutch fan. 12 degrees initial timing with ported vacuum. No cooling issues at all…..and I didn’t clearance my water pump divider plate because I bought the stainless one and I couldn’t get it to move much, and didn’t want to use a BFH
64 GTO with M20 and 3.55 rear
The Following User Says Thank You to 69hardtop For This Useful Post:
  #46
Old 07-21-2021, 06:02 PM
Red face
Pretty sure i use the 180 T-stats for best results. 160 being too cold, and 198 being stoopid hot.
Here's the short block status: Slugs keyed to Rods for thrust surface and valve relief. numbering stamped and sharpied.
Many (6) grandkid interrupts so sharpie keeps the status.
ID:	570197   Click image for larger version
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
  #47
Old 07-21-2021, 06:18 PM
Gm ( ac delco) makes a 170 T stat I have used for many years as well, just a Fyi
  #48
Old 07-21-2021, 10:33 PM
Jay S's Avatar
Jay S Jay S is offline
Working with some serious looking internals for the project. Aluminum rods, look like maybe GRP’s? Be a shame to drop the compression with guts like that. Its saying let’s ROCK…
  #49
Old 07-22-2021, 07:28 AM
Forged crank, BME Rods (+1 GRP matched replacement). Good block.
Maybe best to trade this Flattop shortblock for a dished 455 shortblock!
  #50
Old 07-22-2021, 09:53 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
They BFH is the ONLY way I have gotten the wp plate to move.
I have also carved out a piece of 6x6 and use a little hand press to move it. Past experience has been 1/4" OVER PRESS.(due to memory)...so it lands where you want
  #51
Old 07-22-2021, 10:02 AM
sdbob sdbob is offline
I often wonder how much cam,horsepower do you need for the street,I'm 73? My younger days ran the 068 in 389,400,421.i was happy with overall ,mileage,driveability, performance. Now I'm not into street racing or burning off my tires,breakage.i guess im 'stale'.
The Following User Says Thank You to sdbob For This Useful Post:
  #52
Old 07-22-2021, 04:57 PM
About 400 hp is fine. Any more up to 500 hp is nice but I don't want any compromise in Reliability, high octance additcions, or valvetrain that won't surivive Summer highway.
I think 550+ hp is not happening on 87-89 octane.
  #53
Old 08-17-2021, 08:47 AM
I ordered .080" thick for 4.20" bore, and maybe shipps by mid-Sept. $300 for the pair.
Piston velocity from 4.21" Stroke should keep the quench alive.
Good ting i didn't drive to Norwalk (or local track); the Alum Water bearings were shot to a full wobble. Replace with BMG Alum $48 from Parts geek.
Sum-2821 cam and liftems came in for Spare motor.
  #54
Old 08-20-2021, 02:38 PM
SUM-2821 cam arrived: white boxed, looks fine but no identity stamped on the cam. hmmm.
SUMMIT Lifters arrived: Look fine but pump-up in oil bath not so firm. like .060" play left in each.
Summit Timing Chain: looks fine but upper gear looks lightly used, lower gear looks refurbished. Both are new but sure have their visual ills.
  #55
Old 08-20-2021, 08:52 PM
I would go out of my way and some of the good USA made lifters on this engine. I have some of those white box lifters, doubt I will ever use them on a engine. Not worth the risk.
You can buy a Cloyes "Morse style" heavy duty timing set for 25$.
  #56
Old 08-20-2021, 09:48 PM
slowbird's Avatar
slowbird slowbird is offline
So what are the good US made lifters?
  #57
Old 08-20-2021, 11:36 PM
Jay S's Avatar
Interesting. So there isn’t CWC” cast into the cam core anywhere? That cam appears to be identical to a melling SPC-8, same SAE ratings (rated at .004” at the valve). More or less a RA4 regrind, Summit must have added that fairly recently, I don’t remember seeing it come up on searches in the past.
Best lifters made in the USA are probably between Topline hylift Johnson, Muskegon, MI, which also make the lifter cores for Rhoads. Or Isky’s might be ok yet, not sure what their Pedegre is. No idea who makes summits lifters for Pontiacs, could be Eaton or Delphi?
  #58
Old 08-21-2021, 06:30 AM
Questions,questions.
  #59
Old 08-24-2021, 05:18 PM
Cam core has CWC cast. Just no informative stampings on either end.
Lifters had retaining wire, so i put my last set of C-Clips to the,.
  #60
Old 09-02-2021, 07:09 PM
Finally got the Pan on. 1-piece Pangasket TQd to 12 ft-Lbs. Checked and mostbolts relaxed to 9 ftLbs, so re-torqued to 12. Probably check again later huh.
Rotated engine upright, Put in Cam and lifters with Rev Lube. Then did the rookie move with the Oil Pump Drive: off align. Magnet gotit. Misaligned again and walked away. Really never messed up the oil pump drive install twice.
ID:	572338   Click image for larger version
