Old 04-29-2021, 10:08 PM
tom s tom s is online now
No,6 numbers,3 freeze plugs and 2 motor mounts.Pic in Petes book.Tom
Old 04-29-2021, 10:13 PM
FWI,Nunzi has a factory block with 4.250 bore and NO provision on the side of the block for any kind of oiling.I saw a 366 factory NASCAR block with 4.00 bore when stock was 4.155.My 303 std deck block is just a 70 RA III block with no vin or EUN numbers,just Engineering 303 numbers.They had a great play ground back in those days.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 04-29-2021, 11:50 PM
Dragncar Dragncar is offline
Is this the block that Arnie had with the 2x4 RAV tunnel ram burned up in a barn fire ? 428 RAV 2x4 intended for the Banshee at one point ?
Old 04-30-2021, 12:42 AM
rod cole rod cole is offline
My guess is banjo fittings went there to either provide oil or take it elsewhere. Rod
Old 04-30-2021, 06:17 AM
steve25 steve25 is offline
At any rate it's a real nice Block and I hope it's still fully usable!?
Old 04-30-2021, 07:31 AM
johnta1 johnta1 is online now
RA VI
Old 04-30-2021, 09:27 AM
It is already built as a 428 RA V.Tom
Old 04-30-2021, 10:15 AM
Tom Vaught's Avatar
Boost Engineer
Another question Tom, Does your friends block have splayed main caps?
I saw a block at Butler's many many years ago that was one of Arnie's Special Blocks that had splayed caps and looked similar with the reinforced lifter webbing, (first time for that for me too). I thought that was a great idea and mentioned it to Marty P and that is one of the main reasons why we did splayed caps on his 1967 block.
Splayed Cap Block Tom????
Tom V.
Old 04-30-2021, 10:26 AM
Yes it does.I have heard of them being referred as "the blower block"Tom
Old 04-30-2021, 11:12 AM
grandam1979 grandam1979 is offline
Like this maybe?
Old 04-30-2021, 11:21 AM
Exactly.Tom
Old 04-30-2021, 12:27 PM
Gary H's Avatar
Gary H Gary H is offline
This is one of the coolest threads, and block, I've seen in a long time. Who knew? Too bad Pontiac didn't make them widely available to the general public.
Old 04-30-2021, 12:35 PM
Actually I believe this is diff than the Arni blower block.As I remember when I saw one it was way more heavy.I think it had the unscalloped deck.Been a lot of years since I saw it.Tom
Old 04-30-2021, 02:30 PM
Half-Inch Stud's Avatar
I would have fainted if i found that block in the 1980s junkyarding.
Old 04-30-2021, 06:25 PM
ponjohn's Avatar
ponjohn ponjohn is offline
DOHC McKellar block?
Old 04-30-2021, 06:52 PM
Its just a run of the mill 545687 Engineering angle main 428 block.EO-3777 on the face.G249 daytime casting.Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
Old 04-30-2021, 07:06 PM
It’s not a quick easy thing to make casting mold changes back then, so one would think that they cast up a minimum of 5 blocks with the with the additional bosses in the lifter bores no?
  #38
Old 04-30-2021, 07:25 PM
I would think so if Arni was only getting 25 or so runs on them before they split.Tom
  #39
Old 04-30-2021, 09:06 PM
The DOHC block didn't need a cam in the middle of block, so the lifter area was solid across.
(probably didn't need a lifter valley pan either)
Probably no splitting that block.
  #40
Old 04-30-2021, 09:10 PM
I think them staying with 3 1/4 mains was the real draw back!Engineering had 3in main 4in stroke and 4.21 cranks made.I have owned both of them.Tom
