Old 06-27-2021, 07:58 PM
steve's Avatar
steve steve is offline
Default 81 TO 79 SWAP OUT
who here has taken all the turbo stuff out of an 81 and made it more like a 79 with the 79 wire harness ect ?
1981 Trans Am project -YJ 400 stroked to 488 CID-74cc Eheads-10.95:1-Northwind Intake-Holley Terminator-TH400-Moser rear-Dougs Headers....
Old 06-29-2021, 10:10 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My 81 has a Qjet 400 in it no ECM. Standard wiring like a 79. The 81 temp gauge uses a different ohm range sender than a 78 does.
Skip Fix
Old 06-30-2021, 09:34 AM
steve's Avatar
thanks for the tip. I'm pulling my dash and putting in the new harness this summer/fall. was wondering if Ill have trouble switching over or if it will just be plug and play after the old one is out.
Old 06-30-2021, 09:50 AM
Skip Fix's Avatar
Hard to know if plugs and positions the same. Get some wiring diagrams could help. I was already missing the harness for the computer when I got mine. I just traced oil pressure, water temp, alternator etc wires and hooked them up. I had a 78 water sensor in it when we broke the came in and freaked out looked like it was overheating but not on a temp gum until I found 81 had a different ohm rating and a different thread size also.
Skip Fix
Old 07-01-2021, 01:20 PM
steve's Avatar
my temp gauge reads high as well and the temp gun verifies no overheating.
Old 07-01-2021, 03:03 PM
Skip Fix's Avatar
Could be gauge or sender but 81 sender is needed for 81 gauge..
Skip Fix
