Old 07-13-2021, 10:31 AM
jhein's Avatar
jhein jhein is offline
Default My new 7040263 Q-jet
Yesterday I got my new carb. It looks good. It's going to replace my current carb which is a likely fake 7040273 Frankenstein carb. I can't wait to get it on the car.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 07-13-2021, 05:43 PM
SD455DJ SD455DJ is offline
Very nice! What date is on it?
Dennis
Old 07-13-2021, 05:52 PM
jhein's Avatar
Dennis
Thanks! It's 3409
Old 07-13-2021, 05:54 PM
jhein's Avatar
Old 07-13-2021, 06:03 PM
padgett's Avatar
padgett padgett is offline
Just for S&G, 273 is a RA carb, 263 is a 350hp, both with manual transmissions
Web Site
Old 07-13-2021, 06:19 PM
jhein's Avatar
Yeah, I know. But since there aren't many of those around, I guess I'd rather have a real 263 than an obvious fake 273.
Old 07-14-2021, 06:52 AM
Thanks! It's 3409
Jhein, Thanks! Have you checked out what it has for jets & metering rods yet? My 7040270 (auto carb) had it's original 69 jet/37 rod primaries and DA (.044 M) and 'N' hanger on the secondary side. With today's fuels, it seems a tad lean, so will jet up a little bit after some more shake-out driving.
Dennis
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 07-14-2021, 05:38 PM
unruhjonny's Avatar
incase this helps - taken from my 1970 Rochester book (secondary hanger part number translated thanks to Cliff's book):
jets / primary rods / secondary rod
7040270 = 70 / 37 / CC
7040273 = 70 / 37 / CC
7040263 = 70 / 41 / CC
I believe that the '263 was a smidge leaner on the primary side because of the POE (used on all non-RA Pontiac airhorns that year) which would introduce a smidge more fuel on light or part throttle.
Also incase it's helpful;
7028270 = 72 / 41 / BE
7028273 = 72 / 42 / BE
7029270 = 69 / 38 / BP
7029273 = 69 / 36 / BP
1970 Formula 400
The Following 2 Users Say Thank You to unruhjonny For This Useful Post:
Old 07-14-2021, 05:44 PM
padgett's Avatar
I recall using 70 primaries in just abut everything. 37 rod will cruise richer than a 41. Was just looking for my main Rochester book, black binder withChev/Pont label. Know where within about 300 sq. ft....
Web Site
Old 07-14-2021, 05:52 PM
Thanks Jonny. My RAIV (7040270) original jetting was 70 /39 /CC. Does the Rochester book differentiate between the RAIII and RAIV? It's entirely possible all the metering was changed on this (RAIII 7040270) carb.
Dennis
Old 07-14-2021, 06:01 PM
unruhjonny's Avatar
@ padgett - well, now you don't need to look
@ Dennis - I would wager the metering was adjusted at some point;
These carbs were setup as per application;
I have heard that when these cars were new, it was common for dealerships to perform metering changes to remedy customer complaints ect - and while I don't know if there was a TSB which suggested a metering change, but that's another possibility.
I so would have loved to be around when these cars were new... I'd would have probably always been broke too
1970 Formula 400
Old 07-14-2021, 06:18 PM
jhein's Avatar
So what are the differences between the 270 and 273? Just the linkage for the tranny kickdown or something else?
Also, so then I can change my primary rods and get closer to the RA calibration?
Old 07-14-2021, 07:08 PM
padgett's Avatar
I was around when these were new and was always broke. But was a GMI student on the GI Bill, and had access to Many Things.
(Like an unchromed Buick bumper, Flint glommed onto some of my ideas).
ps in front was my SCCA B/P Z06 FI split window.
Web Site
Old 07-14-2021, 07:43 PM
unruhjonny's Avatar
shoot me an email (as opposed to a private message please);
I'll see If I can be of help.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 07-14-2021, 07:44 PM
unruhjonny's Avatar
I was around when these were new and was always broke. ...
LOL - thanks for that
1970 Formula 400
Old 07-14-2021, 07:54 PM
johnta1 johnta1 is online now
No vacuum port for the automatic kickdown.
(no throttle kickdown on automatic linkage)
Old 07-14-2021, 07:55 PM
BTW, Padgett used to have some good Qjet info on the web.
(not sure if it's still up)
Old 07-14-2021, 10:22 PM
padgett's Avatar
You mean this ? Jon is the expert, I just play at it.
Web Site
Old 07-15-2021, 06:24 AM
You mean this ?
Yep!
Old 07-15-2021, 12:45 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I have Cliffs book - but on Padgett's "How to speak rochester" site he mentions Doug Roe's book. I looked it up on amazon and was surprised to see it was published on January 1, 1672! Lol! Had to share that one. Hopefully that was supposed to be 1972...
https://www.amazon.com/Rochester-Car...6366251&sr=8-3
