Beware!!
There are two versions of the 'Doug Roe' book; the first one is 296 pages, and was first published in 1973; It's a larger book than the one pictured on that amazon link. I bought that book ages ago, then found the original/more in depth version - and sold my copy of that book at a swap meet last year. First version: Second version:
Here are the correct specs for 1970 RA Q-jets
Here are the correct specs for 1970 400 Q-jets.
Here are the correct specs for 1968-69 RA Q-jets.
You made me go and double check;
I did find a typo in my last post that I am embarrassed (if that's the correct word) to now see. Here's what I should have double checked to confirm as being correct: Quote:
Your pages have a November 1971 print date, while my 1970 book has a December 1969 print date. (My 1969 Rochester book has a January 1969 print date.) I cross referenced both of these with my latest printed master parts catalogue (December 1975 print date); It does indeed show #70 jets and #39 rods for '0270/'0273 - so there must have been a TSB issued that changed the metering rod from a #38 to a #39 - neat!
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 07-15-2021 at 03:01 PM. |
Bigger jet and smaller rod is richer.
Wrong vent tube, lack of triangular washer on vent tube, wrong located pump rod, incorrectly adjusted pri to sec axle rod, wrong screws for air valves etc.. I would certainly take a closer look on every part on this Q-jet for authenticity. And, itīs seldom, if ever, a good idea to move jetting from one carb to another without checking the whole recipe and all bleeds, restrictions etc. involved for calibration. FWIW |
The one thing that bothers me the most though is the accelerator pump rod. I even eventually noticed that myself. It's fixed easy enough but if they got that basic thing wrong then what else?? You could say it was just a simple error. But, do you really want a carb built by someone who makes simple errors? So hopefully there aren't more. Like I said, I'm going to put it on and run it and see what happens.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
Why would they cad and not do the rite green.
Dennis |
Thread Tools | |
Display Modes | |
