Old 07-20-2021, 02:32 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Default Cometic 4.380 head gaskets
I'm looking for some .060 head gaskets, but haven't found a set in stock. Anyone know of any shops that may have some in stock?
My current head gaskets appear to be in excellent physical condition, other than slight combustion seepage (about 3/8" wide) between the center cylinders.
If I can't find new gaskets, is it possible to copper spray and reuse the old gaskets?
The block deck looks great and the heads are freshly surfaced.
www.lancablingsolutions.com
Old 07-20-2021, 03:42 PM
Gary H's Avatar
Gary H Gary H is offline
I just bought a set from Butler last week
Old 07-20-2021, 03:59 PM
Mean Green's Avatar
Thank you! I'll give them a call.
Old 07-20-2021, 05:52 PM
steve25 steve25 is offline
What heads are you running?
If they have paired center exh ports it’s a good thing if your running head bolts to take the center two up to 100 ft lbs.
If your running Aluminium heads there deck finish needs to be near mirror like for the best gasket longevity.
Old 07-20-2021, 06:45 PM
Mean Green's Avatar
High port heads. Block and heads are machined for MLS head gaskets.
I wouldn't have an issue reusing the head gaskets, if I was running NA. But this engine is going to be sprayed with a healthy shot of N2O.
Old 07-27-2021, 09:01 AM
aaronman aaronman is offline
Still in need? I have a few sets of different Cometics and would need to check my inventory. IM me. Thanks!
Old 07-28-2021, 11:43 AM
Mean Green's Avatar
They arrived from Butler yesterday.
Thanks though.
Old 08-17-2021, 08:44 AM
Half-Inch Stud's Avatar
I ordered .080" thick for 4.20" bore, and maybe shipps by mid-Sept. $300 for the pair.
