Tri City Launcher springs
So back before Caltracs these were the ticket for Stockers. Greg a Stocker Mopar racer copied Mopar SS springs for GM products. Front of the spring pack stacked and clamped. I got a best 60 ft of 1.51 with a 9" slick in my 78 TA with them. Since I have the Camaro now tacking the TA back to street cornering.
Passenger side spring closer in the picture.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Similar to what I did on my own, I cut the ends / eyelets off a second set of springs used that one for spring #2 and just removed the smallest one in effect it makes the front segment more resistant to wrap up and more like a trailing arm, clamping helps to stiffen and separation on deceleration
Very cool, thanks for posting! Did you have any option as far as ride height was concerened?
I remember talking to Greg many years ago in regards to ordering a set. I think he had a location in California and Michigan at the time. |
Paul it rode like a freaking dump truck! Part of why they are coming off and they lifted the car almost 4". Thye have 5 leafs in them vs the Firebird 4 leafs also.
They flat worked though. On the 78 when racing NMCA I tried just the Herb Adams relocating front spring eye up 3/4" for increased antisquat, then that plus a slapper bar before I ordered these from Greg. I did have the replacement springs made with the second leaf all the way to the spring eye.
Instead of buying from Greg I ended up dealing with Landrum. I was quite happy with them and still have the originals in my 74 that has been mid 1.3 60 ft with Cal-tracs weighing 3860. My brother with the Firebird ran the Landrums for years but recently switched to the Calvert split monos and likes them a lot. My other brother with the Z/28 had some Landrums made with the second leaf extending over the spring eye. They worked great but he hated the harsh ride. |
Squatted with stock springs not with these. I would have them de arched if I ever wanted to use them again. Looked like I had air shocks on it!
Thread Tools | |
Display Modes | |
