Old 07-27-2021, 09:34 PM
Possibly the brake pushrod in the MC/Vacuum booster is wrong length?
That rod goes in a plastic piston. There's a rubber seal that goes between the piston and the case.
I've seen 0-ring type seals and flat rubber seals that are held in by the master cylinder. Unless the piston is broke.. the rubber seal is what's letting vacuum leak.
The O-ring type can be changed by pulling the plastic piston out.
Use to stay covered up at the shop with odd ball stuff like this.
Clay
Old 07-27-2021, 11:48 PM
CEB CEB is offline
Thanks for the lead, abefromen.
Thread Tools
Display Modes
