Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-29-2021, 10:00 PM
AC445 AC445 is offline
Default 455HO heads & 455SD rods at Norwalk
72 455 HO heads 1800,NOS 455 SD rods 700,R-12 freon 25 a can,new Clevite main,rod & cam brgs std 150,new ARP round port head bolts 50,many others.Our spots are on the row close to track half way down next to DME transmissions .
Old 07-29-2021, 10:53 PM
Default ARP bolts-Norwalk
Hello,ARP bolts are for factory round ports,also modified Holley Street Dominator 150,Pro-rebuilt Holley 600 150,Cool Muncie 4-speed long tail converted into mail box post 60,also a buddy has 63 389 parts.
Old 07-30-2021, 07:32 PM
gobrdgo gobrdgo is offline
I’m interested in the heads. Dm d you
Old 07-30-2021, 10:53 PM
Default Norwalk parts
Hello,I just got home from Norwalk. One of the 7F6's was repaired some 35 years ago. We had about a dozen lookers today,but only 2 said they would be back.Probably the repair above both center ex. ports scared the rest away,so I sold the ARP bolts. Thanks
Old 07-30-2021, 11:58 PM
Ok. So the repair is water Jacket ish? If so yeah I’ll pass also. If I was restoring a car it would make sense but money wise probably not worth for me
Old 07-31-2021, 09:41 PM
Default 7F6 heads at Norwalk
I made it home from Norwalk at 9pm. I had at least a dozen more lookers today,and two said they would be back Sunday morning.Just to be clear the old repair was on the outside top of the center ex. ports. IT is from the header flange up 3/4 inch. The previous owner said he ran them for several years before I bought them. Thanks
Old 08-15-2021, 07:38 PM
Pontiac Derek Pontiac Derek is offline
Any pictures?
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
Old 08-15-2021, 11:04 PM
Tom Vaught's Avatar
Boost Engineer
What letter is on the 455 SD connecting rods?
Tom V.
Old 08-15-2021, 11:56 PM
Hello,most parts gone,I ran the ad so members could pick up at Norwalk. Derek,PM your needs. Tom V. I believe they are early B and C's as I packed them for the 2019 show. I may have 1 extra original early no code rod. I can check tomorrow.
Old 08-16-2021, 09:15 AM
Tom Vaught's Avatar
Boost Engineer
Do not bother, I personally will not use any SD Rods with a letter code LESS THAN "E" as those "early rods" have the thin pin end forging. SD rods were produced all the way up to "M" rods in my experience (by Continental Teledyne in Muskegon, Michigan).
Tom V.
Old 08-16-2021, 03:40 PM
Default S.D> rods ,Norwalk
I have actually heard the later letters had problems. Maybe actual builders can post pictures of broken late S.D. rods. I still have 2 that bent,not broke,when a GM 455 crank broke off at number 2 main in the 70's..These were the very early when you could only get 4 at a time from a dealer. Andy
Old 08-16-2021, 06:05 PM
Tom Vaught's Avatar
Boost Engineer
I agree, would be nice to see pictures of those LATER 455 SD rods that were broken.
Tom V.
