Old 03-21-2000, 11:14 PM
Briman Briman is offline
I have a Late 74' Trans Am with a Stock 400. I would like to replace the stock cast manifolds with upgraded (RAIV D Port?) cast manifolds. Does anyone know if this can be done. I would like to install 2.5" pipe with "X" crossover into single flowmaster muffler mounted in original transverse location. Any thoughts on proposed system greatly appreciated.
Brian Peters
Marion, UT
74 400 TA & 74 SD TA
Brian Peters
Marion, UT
Brian Peters
Marion, UT
Brian Peters
Marion, UT
Old 03-22-2000, 10:08 PM
GP-K GP-K is offline
Brian, yes you can use the short style "D" port RA III/HO manifolds (very similar to the SD manifolds) on your 2nd gen T/A.
Your overall exhaust plan sounds pretty good. Nearly identical to the system a friend of mine had on his SD.
Good luck.
K
