Old 11-11-2017, 06:57 PM
Boostedbird's Avatar
Boostedbird Boostedbird is offline
Default Been Quiet
Anybody working on anything?
Old 11-11-2017, 07:17 PM
Tom Vaught's Avatar
Boost Engineer
Helping a member on his V-12 Jag project that will have Twin Turbos and a Doug Nash 5 speed (might be a Richmond 6 speed) in his special body XKE Jaguar.
This guy is a FABRICATOR. AMAZING WORKMANSHIP! Boost system will be the easiest part of the whole deal he has been working on.
Has his Pontiacs but this is a special toy with boost. Assuming +1000 HP for the V-12. Believe it is a 6 liter engine (366 cid or so).
Tom V.
Old 11-11-2017, 07:39 PM
wreckmastr's Avatar
Just suspension upgrades here
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 11-11-2017, 08:20 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
Redoing mine but it's purely street. Nothing like some of these guys. More of a freshen up but changing quite a few things I knew were wrong from day one.. I have another project I just picked up but it doesn't have its place here unless anyone's interested in an 88 RX7 LS single turbo swap?
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
Old 11-11-2017, 08:41 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Putting an automatic in, some suspension stuff, Pulling the heads off for some upgraded cfm
Old 11-11-2017, 08:43 PM
Curious George's Avatar
Curious George Curious George is offline
Not exciting, but changing my oil.
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 11-11-2017, 09:33 PM
Half-Inch Stud's Avatar
changed my rear cover today: Saved the Redline Shockproof because it looks new ( probably re-use it in the 95 Lincoln Towncar).
Brought my 10' manometer home from work, need to hinge it at the 6' level for practicality.
Maybe get back on the on-demand boost. It'sa 2- Stage jobby, jusy above hobo level.
Old 11-15-2017, 03:23 PM
Chris Petersen's Avatar
Chris Petersen Chris Petersen is offline
Send a message via MSN to Chris Petersen
My 79 Trans AM with EFI and a turbo has been sitting a few years now, got side tracked putting LS engines in two mustangs I have. I have too many projects and need to slim the heard.
Anyone interested in a PHS documented 1976 Black on black 455 4sp car with a rear console? I may sell that one to fund the other projects LOL.
463 SRP .035 Pistons, Eagle rods, N crank, Pump gas, Victor intake, Holley 850BT carb, 6H heads,TH400 w/T-Break, Continental custom 3500 converter, 3.73 gears. TV7101 TURBO!
Old 11-15-2017, 09:15 PM
hmmm, need somebody interested in my running 68 GTO that needs passenger 1/4 wheelwell rust repair. Too nice a car for repaint & too long in tooth to say yea baby.
Old 11-15-2017, 09:35 PM
Research and nothing else. I’d like to build a single setup, but I’m too afraid of windowing a perfectly good block that has near stock internals.
-Jason
1969 Pontiac Firebird
Old 11-15-2017, 10:38 PM
krisr's Avatar
krisr krisr is offline
Trying to work out if I have the energy to build a set of manifolds to run a BW S475 T6 1.01 on my 400.... ATM it's a quite healthy street car at 11.7 @ 115 @ 3700lb, so i'm torn to pull it apart as I can drive it anywhere as it is now but boost is the worst drug on the market today.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 11-16-2017, 07:56 AM
Alex_F Alex_F is offline
I have taken a break from my 74 after hurting it at Norwalk. Apparently 25 psi was more than what the stock mains wanted.
But I have been playing with my lemans wagon with the gt45 turbo and bone stock 350. At Norwalk I ran a best of 15.3 with it on 7psi. Since then I added meth injection and turned boost up to 14 psi. First outing with the boost up it went a 14.2 but it wouldn't rev over 4k rpm. So I threw newer stiffer valve springs in it and that seemed to fix that issue, next time out it went 13.5. It was missing out a little at high rpm. So I updated the stock hei with a 6al box and a hotter coil, along with building a 2 step to launch on more boost. That seems to have fixed the miss and I can launch on boost now. But weather has not permitted me to go back to the track. I also put in an exhaust cutout to test the difference between super quiet turbo muffler and open exhaust. Hoping for a 12 my next outting if weather holds! Junk stock engines you don't care about are a blast to beat on. I have a good running spare 350 for when this one kicks the bucket I got for free!
Old 11-16-2017, 11:04 AM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Smile
12 second passes with a free engine in a Lemans WAGON, got to hate that,
Old 11-30-2017, 10:22 AM
7D9TA's Avatar
7D9TA 7D9TA is offline
Swapping from Blow-Thru to FAST EFI. I get to start the tuning process all over again.
Also trying to fix all the little things that broke this year that I just put a "band-aid" on. Its amazing how many little things need minor attention after a year of beating on this thing.
79 TA
476, Single 88MM turbo
Street car. Pump gas, Radial tires, Full exhaust, 4000 LB race weight
Best 1/4
1.39 60 ft
9.03@149.55
