SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
1965 Tripower
Front carb
tag 7025179 airhorn 7013206 bowl 7029683 throttle 15211 Center carb tag 7025175 airhorn 7017917 bowl 7019927 throttle 3530 Rear carb tag 7025179 airhorn 7013206 bowl 7029683 throttle 15211 Intake 9778818 Very complete and quite correct. Includes a box of carb rebuild kits and miscellaneous parts. Pictures: https://picasaweb.google.com/1132638...eat=directlink $1200.00 obo PM, email, txt or call |
On ebay as well.
http://www.ebay.com/itm/230877833326...witem=&vxp=mtr |
Shouldn't the front carb tag be 7025178 ? You have ......79 listed as front and back.
Larry B.
Mr. President, you can't say Dallas doesn't love you " |
Hello??
Checking today.
the front carb did have a 7025179 Tag on it. Not sure if that tag was placed there since original or moved from the back carb. All other numbers appear to be correct on each carb.
What color is the front tag, and, what is the ino stamped on the tag? That will help to I.D. LB
It shouldn't surprise us after 47 years !
It shouldn't surprise anyone that if one of the dump carbs was replaced at some point in its life, you may see this. After all, it was 47 years ago ! Here's a photo of the 3 tags as you would see them (from front to rear) on an OEM 1965 GTO Tri-Power. In the photo, it is just like under the hood, so bottom is front, center is center, and top of is rear. All the Best ! Dave
'65 GTO Hardtop 389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes "What's the point of owning a muscle car if you can't scare yourself stupid from time to time ?" |
Dave, thanks for the post and picture. I am by no means a tripower expert, just pulled the numbers as they were on the carbs. The tag i have for tag 7025179 is C5 73 and the center tag tag 7025175 is c5 58.
I miss cut and pasted at the top of my post. I only have the two tags for two of the carburetors. 7025178 is the tag I don't have which sounds like it should be the front tag. |
What condition are the carbs in? Fully functional or do they need rebuilding?
SIGPIC]http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=139862&dateline=12616 03096[/SIGPIC] http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
The carbs work on the bench. All the linkage moves them and they move freely. I bought this setup 10 years ago and it has sat wrapped up in plastic under my bench for all that time. I would probably rebuild the carbs just to be on the safe side. I have three rebuild kits, two extra two barrel carbs for parts, and a few small boxes of carb parts that go with this set up.
I am going through parts I have not used in some time to clean out the garage. I will sell this one and then find a 65 gto that needs it, always happens. |
bump
Bump
Hammer HIGH…SOLD SOLD SOLD!
