Closed Thread
Old 04-14-2015, 04:48 PM
john marcella john marcella is offline
Originally Posted by mike leech View Post
WTF Magic man how come I don't have a wing?
You still stuck on the wing ding. Old junk , move on.
John Marcella
Marcella Manifolds Inc.
john@marcellamanifolds.net
ph. 248-259-6696
  #42
Old 04-14-2015, 05:12 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by cgeise View Post
Red Bull gives you Wings
I thought the same thing.
Damn I don't have a wing either.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #43
Old 04-14-2015, 05:17 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Apparently John doesn't love you as much as Bill loves Fulton.
  #44
Old 04-14-2015, 07:21 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by Stan Weiss View Post
Tom,
It is easy enough. What do you want it to say?
Stan
Great Example, Stan, THANK YOU, of Dyno Sheet "smoke and mirrors" for the group. Helps make my point perfectly
I want it to say "that Jack made more HP than Fulton", for example.
Using your Bogus Sheet and "fixing" a couple of obvious "mistakes":
You have your BOGUS: "Horsepower Number", your "Uncorrected" Horsepower Number", and the "Correction Factor" Looking "official" there Stan.
But of course if you knew the engine was run in Minnesota you would want to use a Minnesota address vs your computer address.
You also have some acceptable weather conditions: Dyno Air Temp, Dyno Barometric Pressure, and Dyno Vapor Pressure. Looking Good, (All good info to know if you were actually looking at a real dyno sheet.)
So the first actual test to see if the data was bogus by Joe Racer would be to plug the provided 'Dyno Sheet" numbers into this calculator:
https://wahiduddin.net/calc/calc_cf.htm
70, 28.61, .3064 and see what the ACTUAL correction factor would be vs the REPORTED correction factor on the provided BOGUS Dyno Sheet is.
April Fools Joke #1 The calculator says that the actual correction factor should actually be 1.031 (not 1.0672) (:>)
April Fools Joke #2 The Correction factor 1.031 times the Uncorrected HP would be
1058 HP. A convenient 37 Horsepower "error"
April Fools Joke #3 I will post one of my own: Some say that Jack made around 1064 HP so with the "correct" Correction factor (in your BOGUS SHEET times the HP reported, Jack would still make more DYNO HP than Fulton using your example.
So you can "spin" Dyno data anyway you want.
The Track gives the real result.
I really do not care who wins on the actual Race. I just know the actual track result vs the Bogus Dyno Sheet result for example.
So people should not get hung up on some Dyno numbers that anyone could make anything that they want. (Just like you did).
Tom Vaught
Thanks for helping me illustrate my point, Stan.
  #45
Old 04-14-2015, 07:45 PM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
Tom Vaught
... and this is patting Dick on the back .. how ?? ...
... I'll say it again, grow up Tom ...
  #46
Old 04-14-2015, 08:16 PM
T Syron's Avatar
T Syron T Syron is offline
Tom Vaught
So what you're saying is, Dick is a fake? Because after all it's Dick's engine not Bill's. Dick built it, not Bill. Dick dynoed it, not Bill. Dick will be racing it, not Bill.
I think Dick's reputation speaks for itself.
Tom Syron
  #47
Old 04-14-2015, 09:23 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
LMFAO
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #48
Old 04-14-2015, 09:55 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Tom Syron
And so does Tom V's.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #49
Old 04-14-2015, 10:50 PM
"BAE Billet, RM BBC, Australian Prostock, 5.0 b/s Hemi"
... all of these are very much " not old junk", quite the opposite actually ...
... where have you been, under a rock ? ...
ID:	395437   Click image for larger version
ID:	395438   Click image for larger version
ID:	395439   Click image for larger version
  #50
Old 04-14-2015, 11:01 PM
You retard, i was talking about Mikes heads, The wing ding is in my old Pontiac heads i did 10 years ago and i have not done it sence then except for my SB2 heads i put it in. 142 cfm per inch
Thinks always come full circle.
John Marcella
ph. 248-259-6696
  #51
Old 04-14-2015, 11:04 PM
... lmao, well be more clear next time John, it read differently ... but now we're talking, me likey ...
  #52
Old 04-14-2015, 11:32 PM
Stan Weiss's Avatar
Tom Vaught
Tom,
The only April Fools Joke I see is your post. Yes there are a couple of obvious "mistakes". The first and most important is you do not know which SAE dyno correction fact to use. So anything you build on an incorrect foundation is wrong.
Stan
Pontiac Pump Gas List
  #53
Old 04-15-2015, 06:32 AM
Chris Uratchko Chris Uratchko is offline
Wing Dings are cool.
Uratchko Racing Engines
www.ure-racing.com
  #54
Old 04-15-2015, 06:33 AM
The other factor for the correction that weather data won't give you is actual elevation.... which goes into the correction factor, and or DA.
www.ure-racing.com
  #55
Old 04-15-2015, 07:13 AM
Should be using absolute barometric pressure, so that should 'give' the elevation along with the other weather data like dew point and temperature?
  #56
Old 04-15-2015, 07:23 AM
I meant if someone is looking up weather data online for another area of the country, will the data will include elevation?
www.ure-racing.com
  #57
Old 04-15-2015, 07:27 AM
Most do, but a lot of the baro pressure data is not correct though, it's usually 'local' baro not absolute.
  #58
Old 04-15-2015, 07:52 AM
Stan Weiss's Avatar
While looking up weather data is great for a race track, I am not so sure how well that transfers to the conditions in a dyno cell.
Stan
  #59
Old 04-15-2015, 09:56 AM
If you use same dyno/operator and dyno has been maintained/calibrated it matters little what the actual numbers are... it will show changes... if previous hp numbers have always washed with track performance and correction factors there is no reason they shouldnt continue to do so.
  #60
Old 04-15-2015, 10:43 AM
This free site will give absolute barometric pressure (at any track) and, therefore, takes into account changes in elevation.
http://airdensityonline.com/
Jim
7.75 @ 178 pass:
Closed Thread
