#41
Both belts need to ride at the same height of the V groove of the water pump and crank dual groove pulleys or they are competing against each other and not pulling at the same speed.
Kind of like when you pull the venitian blind cords on your window but the cords get out of sync and the window blind raises at a cocked angle. Either way I have not really found a magic solution yet and would love to see an original belt set for measuring purposes. My Gramma's '75 does not seem to shreik nearly as much as the black car did. Maybe that was the reason for the redesigned idler pulley with the open face???? And now, back to our regularly scheduled thread...someone find the correct belt part number(s) please. |
#43
Not so fast...
I'm not an engineer, but it seems like the shaft driven by the opposing belts would simply turn at different speeds and cancel out any tendency for the belts to be in competition. The idler pulley on the Black Car was the open face variety. |
#44
Me neither! LOL
I think the problem is the second pulley (the water pump pulley). If they were just running off the crank pulley to their respective components (alternator and ps pump) there isn't a problem. I think it has to do with the fact that the idler belt set up causes the alternator belt only "ride" in a very small section of the waterpump pulley and thus, skip off it under high loads, making the shriek. See attached photo of The Shriek ZOne |
#45
Belt sizes from earlier post (3/72 dated master parts book)
Alternator: 71-72 All F /455 HO H.T.-P.S. & A.C....545297...BELT (1/2" x 49 3/4") 71-72 A, B, & G-AC, w 80amp............1378417..BELT (1/2" x 51") (this is only belt that could be in question) Power Steering Pump 71 A & F - P.S.-A.C......9789230...BELT...(1/2" x 52" double wrap) (w 80 amp alt) 72 F...........................9789230...BELT...(1/2" x 52" double wrap) (w 80 amp alt) 71-72 All P.S. & A.C. exc X....9790635..BELT..(1/2"x 50 1/2")(w/55amp alt) Air Conditioning Compressor 70-72 All V/8 A.C. exc 307...478012...BELT..(1/2" x 59 1/4") (no issues here) hope this helps.
#46
Steve has it, they squeal at the small point where Both belts are on the same water pump pulley, and as he said , they compete with each other for same speed. Their depth in the pulley can and does change the relative speed by a small amount. The distance down to the idler contributes to radial vibration of the belt as well. ( rocking back and forth as it moves on its path) The fix at the dealer was replace Both belts, and make sure they did not "ride high". WE often measured and got the belts by the old fashioned way, Length, for these applications.
Thanks for re posting the number OPH
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
#48
For a 72 TransAm, there would be 3 different pairs of alt and PD belts, depending on size of two groove pulleys.
#49
Roger, I wouldn't have posted if it weren't (codes were off of a build sheet).
And, the 483780 pick code was P2. |
#50
Thanks Mike, thanks for posting the codes off the sheet.
The only difference I can see between '71 & '72 when identically equipped with Auto, AC, and 80 amp idler pulley is the oh so slight difference in diameter of the 481040 wp pulley, and the 38xxxx wp pulley used in '72. I sure hope Quanta has the correct width and length alt belt, just used in another GM application.
#51
HFR, those match my May '71 VN TA's build sheet in Boxes #35, 36 & 37. How did you connect the pick codes with part numbers? I.E., which box number goes with which belt application?
#53
Does this help at all? It's the build sheet from Gramma's '75 Firebird with the 80 amp setup. And it has HC, GN, GK as the belt codes in blocks 35, 36, and 37.
#55
Trying not to muddy the waters, but Steve your '75 had these belts...
A/C 9433770 (HC) Alt. 9433756 (GN) and P/S 9433753 (GK) Last edited by Held for Ransom; 02-20-2016 at 12:11 PM. |
#56
And, my '74 belt was replaced as it should have had...
A/C 478012 (WH) Alt. 483781 (WG) and P/S 483780 (WC) |
#57
35-PQ 36-P6 37-PZ or P2 My car is a VN 12/70 build. Can you decipher for me? Last edited by hiyabradHO; 02-20-2016 at 01:29 PM. |
#58
A/C 478012 (PQ)
Alt. 483781 (P6) and P/S 483780 (P2). |
#59
9433770 A/C: 7/16" by 59" 9433756 80 amp Alt: 7/16" by 52" 9433753 PS: 7/16" by 51-1/2" Last edited by njsteve; 02-20-2016 at 01:53 PM. |
#60
The '53 is a 50-1/2 belt.
