Rear Axle Width
Does anyone know the stock rear axle width (wheel flange to wheel flange) of the stock Firebird? I have acquired (2) Firebirds with Ford 9" rear axle assemblies and I need to figure out if they are stock width.
Thanks, Eric
I can measure this weekend got the 78's original on a dolly. I know axle length is 31 1/8".
I've got a 9" housing supposed to be for one I can measure too.
Had to go back to office early today so did not get it measured have to go to shop Wed so will get them measured then.
Axles are slightly different length between drum and disc, cant recall if that is carried to the mounting faces or not.
Main thing I found disc vs drum is the brake pilot is longer on disc to locate wheels with the thicker rotor vs drum.
I have a Firebird 8.5 drum brake rear axle sitting in the back yard, if Skip doesn't get the measurement, I can probably do it before we get our predicted 5 inch snowfall on Wednesday.
Eric, you want flange to flange? Mine still has wheels attached so I'd have to remove them, or just get a close enough measurement. |
I'm going to the shop on Wed to cover the new well I finally got put out there this year. We're supposed to have 20s this weekend.
Skip, 61 5/16" outside to outside of each brake drum/wheel mtg surface is what I've come up with in the past. Mentioned this in one of Eric's other posts.
Thanks OPH, I really didn't want to crawl around in the snow to get the measurement if I didn't have to...............
Thanks everybody!
Eric
Backing plate flanges 55 7/8". On the 9" and the factory 78 10 bolt. And the 61" looks close as I could measure on the 78 at the drums.
