Torque specs on valve cover bolts
Hey all, I need some help with torque specs on aftermarket chrome valve cover bolts. I have installed new cork gaskets on new aftermarket chrome valve covers - plain with no sealant or gasket adhesive.
I originally tightened to 36 inch pounds (3 ft lbs) and the leak. I am considering removing and applying gasket adhesive to the valve cover side of the gasket. |
I would suggest you use adhesive to the valve cover side;
I don't use torque specs, instead I gauge by feel with either a stubby ratchet, or a box end wrench. For a worst case, you can often see when the gasket is being pinched.
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
use a good RTV like ultra black or grey or other quality gasket adhesive/sealer & glue to the cover with some weight on it over night to cure. then install & do as mentioned above & tighten to feel, try to get finger snug, then go 1/2 turn further. after a few heat cycles snug up again based on feel.
another option ot get a better seal is to use a thin coat of the RTV on the under side of the gasket too, this is more permanent but will ensure a good seal. i have been able to re use v/c gaskets with light dressing of ultra black at least 1 time after cleaning up the residue on the heads & redoing a thin coat. but if tightened right & rechecked after awhile & periodically each season or so, good quality v/c gaskets should seal with no extra sealer. also be sure the chrome covers arent distorted & areas around the bolt holes are flat. |
